Steering lock problem
Results 1 to 10 of 11
Like Tree24Likes
Thread: Steering lock problem
    Junior Member rex's Avatar
    May 2011
    18
    Anyone have any good advice for this problem?......I have a recently purchased '87 T-Dub and after finding out about the steering lock feature on this forum (the word "lock" was totally faded and scratched out on my ignition switch) I pushed the key in and out in the off position, and then tried to turn it counterclockwise toward the "lock" position.....but it wouldn't turn. Then I put a small amount of PB blaster lubricant on the key and was successful turning it to the "lock" position which of course locked the steering and I was happy .......except that I could not turn the key back to the off or on position even after 30 minutes of jiggling. My brother finally got the key to turn, but I'm too nervous to try to lock the steering again. Do you have to push the key in while turning or do you just turn the key clockwise? Any thoughts about how to fix this? (I would like to be able to lock the steering as a theft deterrent). I havent tried graphite yet, but if the graphite dosent work is it worth getting the keyed ignition fixed, or should I just leave it alone and not use the lock feature? Thanks in advance for any help.
    Ken and jtomelliott49 like this.
    Desert, SoCal
    7,369
    You have to turn the bars fully against the steering stops to disengage the lock.
    Ken, littletommy and jtomelliott49 like this.
    Lower Rio Grande, New Mexico
    1,702
    Rex, Its not entirely clear from your post that you are working with the steering lock. Are you inserting the key in the lock on the front fork assembly totally independent of the ignition lock near the handlebars --- the steering lock has nothing to do with the ignition switch on the dashboard except being operable using the same key?? The steering lock is nothing fancy just a key activated lever that keeps the front wheel from being turned back to neutral position from its position full against the stops when locked. I seldom lock my steering, but thats because my bike is normally parked in my garage or in the boondocks. If it was in town, it would be locked regularly. Maybe your lock just needs to be used to loosen it up. I presume you have found the helmet lock as well. Tom
    Central New Mexico
    Junior Member Miro's Avatar
    Sep 2013
    Croatia
    25
    '87 had a different steering lock system then other years. It is operable by pushing ignition key down, then turning it counterclockwise, front wheel fully left, or right.
    YAMAHA TW200 '87.
    Spokane, Washington
    17,282
    All years are the same I believe.
    Quote Originally Posted by Miro View Post
    jtomelliott49 and Ken like this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member Lomax's Avatar
    Jun 2015
    NE Texas
    301
    Hopefully the OP has figured this issue out by now.. IF not then their might really cheap TW setting in a barn somewhere with a mangled key switch......
    2007 Yamaha XT225
    2003 Yamaha Banshee 350
    2003 Polaris Sportsman 500
    1985 Honda 350X
    1969 Honda CT90
    Senior Member pred's Avatar
    Mar 2016
    Philadelphia and Pittsburgh pa
    545
    +1,
    All the same,
    Use graphite NOT a liquid lube,
    Clean with a touch of brake cleaner,
    Wait a day and use 1 puff of graphite,
    Well,
    Its what I do anyway,
    Lomax, littletommy and Tweaker like this.
    Senior Member mrlmd's Avatar
    1,153
    How did this thread get resurrected? You all know it's 6 years old, right?
    Jun 2016
    New Rochelle, New York
    1,761
    He's still working on that lock.
    Persistance.
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    Keeps wearing out the left side of his tires too.
    TW-Brian likes this.
  1. Noob question- steering lock
    By decade03 in forum Technical Help
    Last Post: 05-29-2013, 11:07 PM
  2. 2002 Steering Lock
    By pizzadude in forum Technical Help
    Last Post: 09-30-2012, 11:20 AM
  3. Question about steering
    Last Post: 10-03-2011, 03:25 PM
  4. Does my '87 T-Dub have a steering lock?
    By rex in forum General Discussion
    Last Post: 07-31-2011, 09:38 PM
  5. Steering lock
    By wayne in forum Technical Help
    Last Post: 07-12-2011, 11:29 AM
2002 yamaha tw200 steering wheel lock
does the tw 200 have a steering lock
how to lock handel bars tw200
how to lock xv250 steering
steering lock problems yamaha xv250
steering lock xv250
stering lock for yamaha tw
tw200 steering lock
tw200 sterring lock
where is the steering lock key number on yamaha xv250
yamaha mio i125 key is locked how to fix
yamaha tw200 steering repair
