TW Main Jets and Crossovers
Results 1 to 4 of 4
    TW main jets are numbered 288-14343-xx-00
    Some TW main jet numbers are superceded by 288-14355-xx-00 numbers
    Some 288-14343-xx-00 numbers are superceded by or supercede 288-14329-xx-00 numbers
    I think we just may have more choices in main jets than one can shake a stick at. Look closely and you can find the #126 and #132.5 main jets that have caused confusion are from the 14355 main jet family, not the 14343 main jet family. Both have worked well for people with the late carbs. Note that the #128 from the 14343 family has been superceded by the #128 from the 14355 family (3rd picture).
    Desert, SoCal
    7,369
    It would also be interesting to verify some of the Mikuni stuff as well. With a set of numbered orifice drills as a gauge you could probably determine whether or not those 112.5's were in fact the same as 112's for example.
    That would be good info to have.
    540
    I am working on this, I have about a dozon yamaha jet measured in mm, dec, drill size all in a spread sheet. If someone has abunch of mikuni and or keihin jets I would be happy to addd them
  1. Wanted: main jets
    By dabiz in forum TW200 Classifieds
    Last Post: 09-02-2012, 09:00 PM
  2. Jets
    By Senior Dirt Dog in forum Technical Help
    Last Post: 08-24-2012, 11:39 PM
  3. Jets
    By RisingSun in forum Technical Help
    Last Post: 11-23-2011, 09:04 PM
  4. where can I get main jets and needle shims for 2006 TW
    By kennethshaw in forum Performance and Customization
    Last Post: 02-03-2011, 03:16 PM
  5. Carb main jets
    By 805gregg in forum Performance and Customization
    Last Post: 11-07-2010, 01:25 AM
