TW200 Issues
Results 1 to 10 of 11
Thread: TW200 Issues
    Member RodneyBR's Avatar
    Aug 2011
    Ajax, Ontario, Canada
    70
    I just bought a used 2006 TW200 and already I have to replace the base gasket. Not a biggie since the bike in still under warrant though GP Bikes.
    But my question is, what else should I expect to go wrong with the bike as it has 6000KM+ on it? Warranty is up in about a month, so I'd let to get GP BIkes to look at any or all possible issues the bike might have.
    866
    Once the base gasket is replaced, you will ride worry free.
    Aug 2011
    70
    Quote Originally Posted by Rodney View Post
    That would be bliss
    Aug 2011
    70
    Oh, I noticed a little knocking from what I believe in the engine, not sure if that is normal?
    Also, it's kinda hard to get into neutral when going from first. I find myself carefully trying to do so, but seems to slip up to 2nd. So I then go back to first and then up to neutral. Sometimes it takes a few tries. Is this normal?
    Sorry for so many concerns, but I would rather get them answered now before warranty runs out.
    Thanks for any recommends, suggestions or anything else I should look out for.
    918
    Quote Originally Posted by RodneyBR View Post
    Probably the valves you're hearing. That's normal. It's a noisy engine.
    Neutral is also an "issue", albeit not a detrimental issue. I usually try for it from 2nd as I rarely get it from 1st, unless it's cold then it pops right in.
    I'd get an o-ring chain (and new sprockets to go along with that chain) so chain maintenance becomes a thing of the past, keep the oil changed, keep an eye on valve clearance and enjoy. Last thing about the oil change, make sure you get the proper filter. There are accounts where others have unknowingly received the wrong filter.
    Sold bike.
    918
    Oil filter questions answered here: http://tw200.wiki-site.com/index.php...ne_Maintenance
    Sold bike.
    Member junk munk's Avatar
    Nov 2010
    Denver, CO
    90
    I bought mine new this past Dec and it makes quite a bit of engine noise, and neutral is hard to find. I find it easier to go from 2nd to neutral, just like on my 2003 Buell,too
    Senior Member dizzle2's Avatar
    Jun 2011
    olympia, wa
    120
    wow, on my 87', it was a little difficult to find neutral at first but with a little experience i can do it no problem.
    Aug 2011
    70
    Something else I noticed is when starting cold, you have to use the choke, which I suspect is normal. And even then you have to press starter for a second or more and throttle.
    Do a complete tune, oil and filter, lube, and service. Then get back to us.
    TWs are clunky shifters. 1960s trans technology. Fresh oil will help, as will a properly adjusted chain.
    North American TWs are jetted very lean. First, do a good carb cleaning. See what main jet you have. You'll likely need a rejet to make the bike run really good. Well worth the $10 and time invested.
  1. start up issues
    By lk555 in forum Technical Help
    Last Post: 04-16-2013, 06:03 PM
  2. 87 CDI Issues
    By keithert in forum Technical Help
    Last Post: 01-19-2013, 06:35 PM
  3. performance issues?
    By Retrofit in forum Technical Help
    Last Post: 09-25-2012, 04:23 PM
  4. Ca. Gas Tank Issues-Need Help
    By ToolBox Guy in forum Technical Help
    Last Post: 04-29-2012, 06:16 PM
  5. Clutching Issues
    By xdac in forum Technical Help
    Last Post: 04-03-2011, 06:59 PM
tw 200 issues
tw200 issues
tw200 oiling issues
tw200 problems
yamaha tw200 issues
