1987 ignition problem
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Junior Member gon2sea's Avatar
    Aug 2011
    10
    i just traded for a 1987 tw200, i am having an ignition problem, sometimes the bike runs fine but most of the time it acts like the timing is jumping and erratic and the engine is pre- igniting / knocking and usually wont idle . when i disconnect the brown wire from the black box ( cdi unit )it runs very smooth but has less power ( maybe no timing advance ..? )i know the 87 has a different cdi unit, is the source coil and trigger coil interchangeable with other years
    and do other year cdi's completely diferent or are just the connectors different.
    540
    if youre in phoenix Az area I can help you
    before going hog wild, we need to determine if the cdi is really the cause. You say it run good and bad, we need more details on this.
    does it cold start fine
    does it idle cold fine
    does rev cold fine
    or
    does it have its poor running condition after its been running for awhile
    answer same as above when hot have hour+ of riding
    does it show the same conditions repetitively/ consistently
    Aug 2011
    10
    all is fine cold or hot when the brown wire is disconnected from the cdi except it is slightly sluggish. with all cdi wires connected there is no consistency, sometimes it starts fine and runs fine, sometimes right off the bat it wont idle, knocks ( pre ignites )and when reved up misses.
    the carb is perfect so we can take that out of the equation. my guess is that when the source coil wire ( brown ) is disconnected it simply runs off the battery but doesnt quite get the same energy as the source coil.
    coil readings are ok, pickup coil g-w is 895 ohms and pickup r-br 453 and br to ground is 35
    i dont have a wiring diagram for the bike, if anyone has a 87 diagram i would love to see it...!
    neutral swith is disconnected, side stand switch is unplugged and so is the clutch switch.
    i dont have any test readings or specs on the cdi box so i cant test it but thats hit and miss unless you have a factory " load " tester.
    540
    ok then----- btw Never count out a carb.......
    now make sure there is no cut, broken, shorted wires, intermittent shorts anywhere. I have seen pinched wire coming out of the clutch cover from when people were fix an oil leak or changing the primary sprocket.
    Aug 2011
    10
    thanks for the input but without a wiring diagram its much harder to trace anything withot peeling the whole harness appart however there are no exposed wires under the cover ( i checked) the 87 was an odball as things changed in 88. for background info , in 1984 i was the official mechanic for bmw at the national rally at laguna seca, in 1981 i built and was the mechanic for the paris to dakar rally bmw and in late 83 built the winner for the craig vetter mileage rally at sears point among other things, so i can safely state that the carburetor is fine.. but yes, it is not a point to be overlooked...!
    540
    540
    here is your pesonal bible, read it - learn it - know it
    you will be tested
    http://www.mediafire.com/?o6lhw4g5oc7omb4
    from the pinned technical section
    Aug 2011
    10
    wow, thanks, its so much easier to navigate in the dark with a flashlight...i mean a wiring diagram.. it kind of points to the cdi box, especially when the motor runs smooth again for a bit everytime i knock the cdi against the frame... touchy little buggers..
    i have a REALLY odd cdi box on my honda quad.. the stock box will only fire when you touch it.. all you have to do is put one finger on it, no pressure, no squeeze, just touch it when hitting the starter button and it fires right up.... ive tried wrapping it with foil and grounding it thinking that the touch was grounding it... nope, no success.. no rhyme or reason. the quad runs great with an aftermarket box so now i keep the stock box as a spare.. of course they make cheap aftermarket cdi units for honda... the cheapest i can find the cdi for the tw is $220...going down baja in 4 weeks so my girlfriend can have a "toy ' to ride on the beach...
    thanks for all the help, two brains are better than one..
    thanks.
    eric
    Jul 2011
    1,123
    Interesting stuff. I have a 91 that was running like junk (would run ok for a bit then fall on its face and act like it was running out of gas). I suspected the CDI and confirmed this by swapping in a known working unit from another bike.
    Now I have been attempting to repair my broken CDI, and after removing the case and potting compound (and not doing much else) I have taken it for a test ride... it runs much the same as you describe yours running with the brown wire disconnected. It no longer is completely unridable due to random problems that would often bring me to a halt in traffic, but it also does not have the "power" that it did before.
    Have to wonder if I wiggled something that fixed the first problem, but also broke something else causing it to have very little power....
    ITCB
    Aug 2011
    10
    it definitly is the cdi box, every now and then when it runs if i wiggle, tug/push the cdi wires by the box the bike will cut out, if its running rough the reverse happenned, it would run fine... and finally i decided to " squeeze ' the box and it would run fine... so, now i have two small pieces of wood across the box held on with a hose clamp, runs like a champ...
    so, for now, its fixed untill i get a new cdi... ive had 4 tw's thru the years an 89, 91, a 2002 and now this 87 and this is the first one that gave me trouble, there great little " do it all " bikes...and wonderful to teach someone how to ride
  1. Another 1987 CDI problem solved
    By vn_grnt in forum Technical Help
    Last Post: 11-18-2017, 10:12 AM
  2. Ignition Coil
    By BC4Lyphe in forum Technical Help
    Last Post: 04-02-2013, 08:24 AM
  3. In need of tw ignition switch and key
    By andrewsclues in forum TW200 Classifieds
    Last Post: 10-15-2012, 07:01 PM
  4. 1987 TW200 Ignition/Electrical Problem?
    By snowrider in forum Technical Help
    Last Post: 05-31-2011, 05:58 AM
  5. WTB Ignition switch
    By brownie2 in forum TW200 Classifieds
    Last Post: 10-04-2010, 09:23 PM
1987 bw200 cdi
1987 bw200e pickup coil
1987 tw 200 cdi
1987 yamaha bw200 cdi unit assembly
1987 yamaha bw200 ignition
1987 yamaha rd350 f11 side stand wire diagram
1987 yamaha tw200 wiring diagram
tw200 ignition problems
wiring diagram on yamaha tw 200
yamaha cdi unit 1987 200 bw
yamaha tw cdi unit
yamaha tw200 electrical diagram
