O-rings that go bad often.
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
    After going through the hassle of o-rings getting hard and leaking and changing this or that on a regular basis, I developed an o-ring replacement schedule that replaces them before they start leaking. to save money I took OEM parts to an industrial seal supply and had them matched up. I've been using the industrial parts for 40,000 miles and saving a to of money, and not having leaking o-rings.
    I'm putting together an order for Viton o-rings for Tdub's next 48,000 miles as I'll be out of stock after the next service. I've found industrial Viton o-rings at least as durable as the Yamaha parts and significantly cheaper. Here's the "kits" I'm going to bag up for myself and the intervals T-dub needs them replaced to avoid leaks.
    My maintenance intervals are:
    2000 miles--change oil
    4000 miles--change oil and filter, check valves
    repeat
    My o-ring replacement intervals are:
    2000 miles--oil change kit
    4000 miles--oil change kit, oil filter change kit
    6000 miles--oil change kit
    8000 miles--oil change kit, oil filter change kit, valve adjustment kit
    repeat
    Contents of kits:
    1) Oil change kit:
    Oil fill cap, oil drain plug. Every oil change.
    2) Oil filter change kit (every other oil change):
    Oil filter cover, shoulder bolt.
    3) Valve adjustment kit (every other oil filter):
    Rocker cover (2), large plug on side cover (1), small plug on side cover (1). Every other valve adjustment.
    I've not had to replace any other o-rings, so I'm not messing with them.
    I'll be putting each "kit" in a ziploc bag with an index card saying what it is. If anyone is interested, 50,000 miles worth of o-rings for the stated schedule will fit in a USPS Priority Mail Domestic Small Flat Rate Box that ships anywhere in the U. S. of A, FPO, and APO, for about $6. I think a USPS Priority Mail International Small Flat Rate Box ships most everywhere else for about $15.
    I'll call Monday and get prices if anyone is interested.
    Member Byte's Avatar
    Nov 2010
    56
    Sounds like an excellent maint sched. I'd definitely be interested in getting a lifetimes worth of o-rings. I'm just getting ready to do an oil change here at 1800 miles. When I ordered a few filters I totally forgot to grab o-rings. Hate to go over to the Yamaha dealer and pay a few bucks for each of them.
    Let me know what you come up with for costs.
    Byte
    540
    O I will buy- do you combine shipping
    Senior Member BBMS's Avatar
    Nov 2010
    Pensacola, FL
    103
    I would like a set as well. Mark
    A small Priority Mail Box or Envelope will hold several sets. First time I did this I stuffed all the sets in a 1 gallon ziploc.
    Kit contents (prices from online Yamaha source):
    Oil change kit--24
    1.96 93210-19123-00 oil fill
    1.33 93210-347A1 drain plug
    3.29
    Oil filter change kit--12
    4.08 93210-54175-00 oil filter
    1.32 93210-07135-00 shoulder bolt (allen head)
    5.40
    Valve adjust kit--6
    5.09 93210-57634-00 rocker cover (2)
    2.49 93210-32172-00 large side cover plug (rotor bolt)
    1.65 93210-14369-00 small side cover plug (timing marks)
    9.23
    Other:
    3.51 93210-25711-00 starter drive
    Monday we'll see how the prices shake out.
    Senior Member Bagger's Avatar
    Jan 2011
    Central WA
    1,050
    Qwerty,
    Thank you AGAIN for your diligent work. I have a couple of differant o-ring kits in the shop, but it would be great to have a kit made up and handy.
    In that light, I would like to purchase two kits. One for both D's and my bike.
    Thanks again!
    Bag
    "The TW may be slow, but the Earth is patient" - MK
    "If I'm wrong, and it turns out that you hate it, I'll send you all my Barry Manilow albums." LB
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    Add me as interested.
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    I've e-mailed my source with all the info for a price quote.
    Senior Member bangkokbonk's Avatar
    Jan 2011
    Koh Kood Thailand
    211
    I'll take a set please Querty
    About to attempt my first Bike maintanance and repair ever. was in the process of sourcing some.
    I take it youve got pay pal?
    Cheers, nice one
    1996 TW200 Edmonton, AB
    590
    Put me down as interested too.
    Paul
  1. Buying Piston Rings
    By canadainshiver in forum Technical Help
    Last Post: 05-05-2013, 11:37 PM
  2. Carb gaskets and o-rings
    By azbusmo in forum Technical Help
    Last Post: 04-22-2013, 06:38 PM
  3. Oil Filter Cover O-Rings
    Last Post: 09-19-2012, 05:38 AM
  4. o-rings
    Last Post: 03-10-2012, 09:46 AM
  5. O-rings
    By elime in forum General Discussion
    Last Post: 12-21-2011, 10:54 AM
do o rings go bad
do o rings go bad over time
tw200 orings
why do o rings come out so often
