Puffing smoke
Results 1 to 10 of 13
Like Tree20Likes
Thread: Puffing smoke
    Senior Member SickPuppy76's Avatar
    Glenville, NY The Vampire State
    667
    Puffing smoke
    The group I rode with today said my TW was puffing smoke when I was downshifting to control my downhill speed, and upshifting up hills. Is this normal or do I need valve adjustments?
    jtomelliott49 likes this.
    "SickPuppy76"
    Greg from Glenville
    2014 TW200 rear Cyclerack with bag supports and Versapack saddlebags, upgraded foot pegs, Mad Dog seat cover
    2014 Nissan Pathfinder 4WD
    2005 Buick Rainier AWD
    2001 Bass Tracker Pro Team 185XT
    Old Town Trip10 Angler Kayak
    Senior Member haroman145's Avatar
    Nov 2015
    Havelock NC
    170
    How many miles on your bike? Are you using considerable amounts of oil? Valves being out of adjustment shouldn't cause you to burn oil.. Maybe if the exhaust is excessively tight creating more crankcase pressure.
    Most likely you just overfilled it with oil. Causing an increase in crankcase pressure, pushing the oil into your airbox.
    Otherwise the most common places for oil bypass is valve stem seals (smokes at cold start) Or around the piston ring. Both will get consistently worse over time.
    Just check your oil religiously. If your burning a little bit its not the end of the world. A little extra lube wont hurt.
    1987 Yamaha TW200
    1999 DR 350 SE
    2008 Beta 525 RR
    6,981
    Burning a little oil will carbon up the combustion chamber thereby increase the compression ration and giving you more power. A silver lining to every cloud!
    Lyterx and jtomelliott49 like this.
    667
    My bike is 19 miles shy of 5000. Last time the valves were adjusted was 600 miles. Runs like it did when it was new. Oil level looks fine and oil is clean, it was changed at 4300 miles, at which time they told me it was low on oil, so is apparently using some. The previous oil change was at 2200 miles. So I'm checking it way more often now, like every ride.
    jtomelliott49 and littletommy like this.
    "SickPuppy76"
    Greg from Glenville
    Nov 2015
    Havelock NC
    170
    Quote Originally Posted by SickPuppy76 View Post
    Having oil changes and valve adjustments done somewhere else? Do it yourself, save some money and get piece of mind that the maintenance actually got done.
    littletommy likes this.
    1987 Yamaha TW200
    1999 DR 350 SE
    2008 Beta 525 RR
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Colorado
    1,166
    Sounds like piston rings?
    Downshifting/engine braking regularly instead of using the brakes can wear out piston rings quicker [not implying you do this- just a thought]. Worn rings would lead to excessive oil usage, more so at higher rpm.
    Also if it was leaking from the top a valve adjustment would not solve anything, you would need to replace the valve stem seal. #6 on this picture:
    2009 Yamaha TW200 (TW200Y) Valve | MRCycles
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    Try changing the oil again.What oil are you using??I change mine every couple hundred kms or when it starts getting hard to shift gears.It only holds a liter so the oil takes a beating and may break down quicker.
    Senior Member peter's Avatar
    Jul 2011
    Providenciales, Turks & Caicos
    398
    Quote Originally Posted by ssgtrillium View Post
    Wow, that a lot of oil changes. I change usually after 2,500 or 3,000 miles. Have 24,000 miles on one TW and 13,000 on the other. But I must admit, I am always surprised how easy it is to shift after an oil change.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,393
    valve adjustment has nothing to do with burning oil. worn valve seals will give a puff of blue on a cold start and worn rings will show blue the rest of the time
    haroman145, littletommy and Purple like this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Nov 2010
    Frostbite Falls Ill
    2,719
    I used to puff smoke a lot but I quit in 81 on my doctors advice. Puffing smoke is not good for you or your bike unless one of you is a two stroke..
    Rings and valve guides are the most serious possibilities, but check the possibility of oil in the air intake system first, possibly from breather tubes to the air intake box.
    A compression check can reveal worn rings.
    littletommy and SickPuppy76 like this.
    Phelonius
  1. Overhauled - breaking in w/ white Smoke
    By Skin Walker in forum Technical Help
    Last Post: 09-09-2016, 12:25 PM
  2. Deep Purple playing Smoke on the Water
    By Croatoan in forum Off-Topic
    Last Post: 02-04-2016, 07:44 PM
  3. Lots of white smoke
    By wayno in forum Technical Help
    Last Post: 02-25-2014, 11:01 PM
  4. tw200 engine smoke
    By Danport in forum Technical Help
    Last Post: 09-11-2012, 01:59 PM
