rear sprocket
Results 1 to 5 of 5
Thread: rear sprocket
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    ok i just wanted to ask before i go and spend money for nothing.sprocket question: drop a tooth on the front and get more low end snap, i do this on my crotch rockets and is a standard mod. to acheive more top end speed you drop teeth on the rear? i see alot of people are running a 47 tooth rear sprocket. how much gain in top end speed is there? im running stock sprockets right now which i think is 15 front 50 rear.i snapped the stock chain at only 265 miles on it so i may as well just get the most heavy duty set up i can find. any suggestions would be great.
    Sebastian has a 520 conversion available.
    Stock sprockets are 14/50. It is a good all around combo. 15/50 or 14/47 will allow more function in 1st on the street and less vibration on the highway. There will not be any gain in top speed for most riding conditions because a stock TW will hardly pull redline (74mph) with the stock sprockets unless going downhill.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    Good information from qwerty. I have been running and really liking 15/50 for several thousand miles now. It is very usefull for street and highway riding. I think I tried just about all the other street combos. If my o-ring chain ever wears out I may try 15/49 but as qwerty aluded to Tdubs don't have enough power to pull higher gearing. It takes a while to accept, but if you want performance you need some revs.
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    Desert, SoCal
    7,369
    Quote Originally Posted by Turtle Chaser View Post
    Well stated.
    Jul 2011
    putnam,ct
    428
    good info, first gear does need a little help. its good to know not to expect any speed gain as well. thanks a bunch.
  1. Dual Rear Sprocket 45T & 50T
    By koonercat in forum Technical Help
    Last Post: 06-15-2012, 06:46 PM
  2. Replies: 0
  3. 60T Rear Sprocket??
    By NHebayer in forum Technical Help
    Last Post: 06-11-2012, 11:35 AM
  4. Rear sprocket change out
    By k9scooter in forum Technical Help
    Last Post: 10-06-2011, 06:05 PM
  5. New Rear sprocket problem
    By mga60tw in forum Technical Help
    Last Post: 11-13-2010, 01:12 PM
