1999 lighting question
Results 1 to 2 of 2
    Junior Member designmaki's Avatar
    May 2011
    4
    I recently purchased a used tw200, this is my first on road/off road bike.. and I am pretty new to bikes in general.
    When I got the bike the gauges worked but the plastic was broken up so I decided to put a new gauge on it. I looked at some posts and decided to go with a drag specialist mini speedo with the neutral light, high beam light, and turn signals.
    I installed it based on the instructions and did a solder splice on them..turned out really good but have a question about the lights now.
    When the bike is on either high beam or low bean the front turn signals are on.. this might be how it is stock and just never noticed.
    When I use the turn signal the still flash in both the front and back.
    Should the fronts be on all the time? if so should the rear turn signals be on as well?
    Just curious if I did it right cause in the instructions there was something talking about a diode and maybe having to install it..
    Hopefully some one can inform me if I did it right or not.
    Thanks
    Desert, SoCal
    7,369
    The front running lights are always on. All good.
  1. Front end swap 2006 to a 1999
    By KENNYGEORGE in forum Technical Help
    Last Post: 03-26-2013, 10:34 AM
  2. For sale: 1999 TW in St. Louis $1800
    By Jch in forum TW200 Classifieds
    Last Post: 09-10-2012, 08:36 PM
  3. 1999 Gas tank and plastic for sale
    By Boarder255 in forum TW200 Classifieds
    Last Post: 12-23-2011, 10:39 PM
  4. 1999 yamaha tw- $1400
    By yoter in forum TW200 Classifieds
    Last Post: 06-07-2011, 01:51 PM
  5. 2006 TW200 $1999 Boise, ID
    By JPonce05 in forum TW200 Classifieds
    Last Post: 11-14-2010, 05:38 PM
turn signals
