fuel hose sizing
Results 1 to 5 of 5
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    I've searched,but, no luck.....I'm at work and can not find what size fuel line/hose our TW's use......I'm going to put a fuel filter in the line(in between the petcock and carb). I was looking at fuel filters and the ad's advised as to what size fuel line/hose their filter would fit?????. I figured on using a VISU filter???. Anyone advise on the fuel line size and/ or a better type/ brand of fuel filter?. TIA.
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    I didn't actually measure it, but I did take a look at the one on my 03 and it appears to be 6mm (1/4").
    Jun 2011
    SW, Ohio
    2,518
    Thanks lefti!
    Ephrata, WA
    1,125
    If you get a fuel filter that has the barbs on it, it may be difficult to get the filter into the fuel line. I took a razor blade and shaved off the barbs and the filter slipped right in.
    1990 TW200
    Jun 2011
    SW, Ohio
    2,518
    Thanks rainman....good info!.
  1. fuel hose routing
    By bikerjosh in forum Technical Help
    Last Post: 02-18-2013, 04:24 PM
  2. front brake hose
    By 671tdub in forum TW200 Classifieds
    Last Post: 01-11-2013, 04:47 PM
  3. photo sizing for knuckleheads
    By yamamont in forum General Discussion
    Last Post: 10-02-2011, 10:18 AM
  4. coasting enricher hose
    By TWhog in forum Technical Help
    Last Post: 09-28-2011, 09:16 AM
  5. sizing for hi viz vests
    By peruano in forum General Discussion
    Last Post: 07-11-2011, 09:23 PM
fuel hose size tw200
fuel line hose for yamaha tw200
tw 200 fuel line size
tw200 fuel line size
tw200 visufilter
