Carb questions
Results 1 to 6 of 6
Thread: Carb questions
    Jun 2011
    AZ
    793
    Bought a K&N pod filter and a supertrapp muffler. Now when I let off the gas I get a poping sound. Do I need to get a bigger jet cause the air and exhaust flow is better? Arizona is the area by the way.
    918
    Yes, and you should install it yesterday. And you'll need to alter your mixture screw.
    Sold bike.
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    I am adding a Beams style low header/exhaust and K&N pod. I am planning on starting out with a 118 jet and will tune from there. I have also turned my mixture screw to 2.5 turns out as a base point as well. YMMV.
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    Post
    sorethumb, i had the same popping issue as you have now. first i tried just a carb jet which was the #130, still popped on decel. then i shimmed the needle with one .020 inch shim, still popped. then went up to a #132 jet and two .020 inch shims and now all is well. like some of the advanced members say, do little steps until you find the sweet spot.
    mr zaninni speaks wisdom. Make adjustments one step at a time as long as results are positive. Main jet first, then needle shims, then pilot screw.
    Bluffton, SC
    663
    Mr Z., I think you meant to address Rising Sun, not me. Your advice is spot on though-I intend to adhere to Qwerty's carb tuning bible.
    If my bike is making popping sounds at the moment, it's more than a carb problem...
  1. Lazy Man's Carb Cleaning Questions
    By Avi Kwame in forum Technical Help
    Last Post: 04-09-2013, 07:06 PM
  2. A few questions
    By nfpgasmask in forum General Discussion
    Last Post: 12-10-2012, 01:30 PM
  3. last round of carb questions
    By phazer in forum Technical Help
    Last Post: 08-06-2011, 05:44 AM
  4. more carb questions
    Last Post: 05-24-2011, 08:31 PM
  5. Newer CV carb vs. older carb. MPG
    By number356 in forum Technical Help
    Last Post: 03-28-2011, 11:25 AM
