1987 model - upgrade electrics - possible?
Results 1 to 4 of 4
    Junior Member DrT's Avatar
    Hutton, Essex, England
    24
    I own a 1987 model, which I may wish to upgrade. I know that the rotor, stator, CDI and LH case are unique to the 87 model. However, I was thinking about replacing all of those with a set from a later model and re-wiring using a corresponding wiring loom. Does anyone know whether or not this is likely to be possible?
    Jul 2011
    1,123
    Lizrdbrth has explained this all pretty well on the board. These two links should get you started
    https://tw200forum.com/index.php?/top...__1#entry21366
    https://tw200forum.com/index.php?/top...7-wtb-90s-cdi/
    ITCB
    Senior Member greendub's Avatar
    Montgomery, VT
    220
    We just swapped a 94 electrical into an 87. Stator magneto, pulser coil, rectifier, cdi and harness. Only difference we noticed is that the newer models have running lights off blinkers. Don't plug in the blue wire and they work the same.
    24
    Quote Originally Posted by greendub View Post
    Did the components fit into the 87 outer engine case or did you have to replace that too?
  1. 1987 Model Year - First Year for TW200's - Good, Bad, Ugly?
    By TW-Brian in forum General Discussion
    Last Post: 01-07-2019, 01:52 PM
  2. Cam upgrade
    By Skyking in forum Performance and Customization
    Last Post: 01-07-2012, 01:39 PM
  3. Simplify the electrics
    By leborico in forum Technical Help
    Last Post: 12-25-2011, 11:00 AM
  4. Dead Electrics on Key Turn
    By ezman671 in forum Technical Help
    Last Post: 12-06-2011, 10:09 AM
  5. 1987 - 2000 Model Carb Tuning
    By treybrad in forum Technical Help
    Last Post: 08-03-2010, 09:30 PM
