clicking clutch
Results 1 to 4 of 4
Thread: clicking clutch
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    i guess there really is a first for everything. never heard a clutch do this befor. with the bike not running if i pull in the clutch i can hear the clutch making a clicking sound.the click is coming from the left side of engine. it happens when the clutch lever is pulled in about a half inch. cant really tell if it happens when bike is running cause i cant hear it over the normal engine volume. even with the clutch cable tight or loose it still makes the click at the same volume, and at the same place. before there was no noise when i pulled in the clutch, very quiet.i plan on replacing the clutch disc's and springs this winter but thats still a ways away.
    Check the spring under the lever where the cable hooks up.
    Jul 2011
    putnam,ct
    428
    spring is good, sound is coming from inside of the motor.
    918
    The clutch discs and basket are on the opposite side, must be your linkage inside.
    Sold bike.
  1. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  2. Clutch Help
    By xdac in forum Technical Help
    Last Post: 02-23-2013, 06:52 PM
  3. Clutch
    By wsb1206 in forum Technical Help
    Last Post: 10-26-2012, 04:29 PM
  4. Solenoid or Starter Motor? Clicking sometimes
    By tw200sgp in forum Technical Help
    Last Post: 09-03-2012, 03:49 PM
  5. clutch
    By bratliff in forum Technical Help
    Last Post: 09-20-2010, 07:39 PM
