Engine Problem
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Engine Problem
    Member chasejamy's Avatar
    Sep 2010
    Calif.
    59
    Coming up the road today in fifth & was losing rpm, happen in fourth third & second. I have 1800 miles
    on my bike. I pulled over. I went & got my trailer & got the bike home. I put it fifth & tried to push it
    but tire locked up. Pull the spark plug it looked great. Pull the oil filter look great. Do you think the cam might be stuck?
    Any suggestions would be great. I am shocked that it happen. Plus it won't turn over, it just clicks. Mike
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    Quote Originally Posted by twhunter View Post
    What year is the bike? Have you checked you batteries voltage, and also are the battery terminals clean and tight? How about your oil level?
    Sep 2010
    Calif.
    59
    It is 2008. Oil level is right on, changed oil 25 miles ago. What I was thinking since it is hard to move the bike in fifth gear
    something has to be locked up. I tried to move the bike with the clutch out. I guess something could come loose in the top
    end, i am really disappointed. Mike
    Sep 2010
    Calif.
    59
    Does any one know where to buy a manual for the tw 200, I don't want the cd. Thanks Mike
    918
    Does it start as is? Idle good? Use the correct oil filter?
    Mine will lock the tire in 5th too if I'm near TDC. Or if the rear tire can't grab enough traction.
    There's a free pdf of the manual in the technical service folder, download and print it. If you don't want that, eBay is an option.
    Sold bike.
    Sep 2010
    Calif.
    59
    Yes it did, before this happen. Never had a problem. It ran great. What would you suggest, take the top end
    a part? Mike
    918
    You can pull the cam without having to removing the head. Saving yourself a gasket.
    You could check the valve clearances and see where they are sitting. The locknut could have came loose, valve clearance goes out of spec and you get your running condition.
    You could do a compression test or leakdown test to test the piston/rings.
    You have more options than tearing it apart.
    Maybe just a tank venting issue?
    Does it idle now? Meaning, after you had this issue.
    Sold bike.
    Sep 2010
    Calif.
    59
    It won't start, it just clicks. Battery is in good shape, lights are bright.
    Member Fourcycle's Avatar
    SE Michigan
    78
    Sure it's not the dreaded wrong oil filter issue is it? The look-alike, fit-alike oil filter that doesn't have the holes for allowing oil into the top end? Sure sounds like it
    If your only tool is a hammer
    Everything looks like a nail
    Sep 2010
    Calif.
    59
    I will check out the oil filter. If it is the wrong one, does it mean bad news? Mike
  1. A problem with my new TW
    Last Post: 12-09-2012, 05:22 AM
  2. I think I have a problem
    By n2o2diver in forum General Discussion
    Last Post: 12-20-2011, 06:16 AM
  3. TW 125 starting problem
    By tw125 in forum Technical Help
    Last Post: 08-01-2011, 01:15 PM
  4. tw200 problem
    By dizzle2 in forum Technical Help
    Last Post: 07-22-2011, 02:47 PM
  5. wiring problem
    By mikeparr123 in forum Technical Help
    Last Post: 07-19-2011, 07:02 PM
tw200 engine failure
