Old oil filter
Results 1 to 8 of 8
Thread: Old oil filter
    Member Lido's Avatar
    Sep 2011
    64
    I just got the carb all cleaned up but I forgot to pick up an oil filter to replace the old one when I was at the dealer. Does anyone know how bad it would be to try and start the bike with the old filter installed ? The oil in new but the filter is aBout 8 years old which is the last time the bike was ridden. The dealer wont be open till Monday but I really want to see if the bike will run . I won't ride it just see if it starts. I promise . What do you guys think???
    Senior Member BillMichaels's Avatar
    SF Bay Area
    277
    It all depends if the old one has a stock brass screen. Spray the heck out of the old one with WD40 to remove any metal junk and if it doesn't have any holes in it give it a try.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
    Agreed. If it's the original brass screen type, clean and go. If it's fiber type, I wouldn't risk it.
    Sep 2011
    64
    Ok thanks! I will clean and give it a go.
    SF Bay Area
    277
    If and when you replace the brass filter make sure you get the correct one with the holes in the rubber ends. Search this site for the "Correct" and "WRONG" OEM Yamaha filters.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
    Sep 2011
    64
    Thanks for that!!! I will make sure to get the right one
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    It's not what the sales guys says, or what the numbers on the box 'imply'. The filter MUST look like this on the end. Gerry
    Take care my Friend.........
    Sep 2011
    64
    Thanks Gerry !!!
  1. Oil filter mix-up
    By accor415 in forum Technical Help
    Last Post: 07-04-2014, 08:47 AM
  2. Oil filter
    By cat 4 life in forum Technical Help
    Last Post: 06-17-2013, 08:11 AM
  3. Air filter Mod
    By jimmytanko in forum Technical Help
    Last Post: 10-03-2012, 06:41 PM
  4. oil filter
    Last Post: 07-06-2012, 09:00 AM
  5. K&N oil filter
    By brownie2 in forum Technical Help
    Last Post: 12-24-2010, 12:28 AM
