Starting circuit cut-out relay - mixed messages?
Results 1 to 10 of 13
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    According to the flow chart of finding starter problems, one is to connect a jumper to the negative post of the battery from the sky-blue wire at the harness. This should turn the starter with the switch. It does not, but there is a healthy click in the relay when I touch the battery post. Every other test works good in this sequence; but the thing sounds to good for toast. What do the experienced have to say? GB
    918
    1) Is the click you are hearing from the starting circuit (ckt) cutoff relay? Or from the starter relay (as labeled below)?
    2) Can you jump the starter relay to get the starter to spin? That should prove out the starter itself as being good as well as sufficient battery power to spin the starter.
    3) If the starter and battery prove good, then I'd prove out the starter relay (with jumper wires from + to L/W and ground to R/W on the trigger terminals). You should test the starter relay by itself as there's always the chance the starting circuit cutoff relay (upstream of the starter relay) is clicking but not actually connecting terminals internally.
    4) If starter relay is good then you end up at the starting circuit cutoff relay.
    5) Just in case, is the kill switch in the ON/RUN position?
    Sold bike.
    Aug 2010
    264
    Thanks pg,
    Yes, those are in the steps leading up to this. Starter is great, better than my leg. Doesn't need to be choked if I jump it at the starter relay;
    it is suddenly idling away in front of me. The manual flow chart brings me to this relay and the click is contact of the jumper to ground, not the start button. I can also feel it with my finger. So can it be toasted and still click away happily? Remember, everything else spins the starter.
    GB
    Jul 2011
    1,123
    I'm not familiar with the relay you speak of, but if it were any other relay i would remove it from the system and set it up in a test circuit to be sure it works properly if it were questionable and difficult to isolate on the bike.
    Screw listening for clicks, apply voltage and make sure the damn thing is switching like it should be.
    ITCB
    918
    Trigger the relay at the input terminals (you should then hear that click) then you could try a continuity test (or check resistance) between the output terminals. If it clicks and there's no continuity (or infinite resistance) then it's moving internally but not connecting the output terminals.
    Sold bike.
    Jul 2011
    1,123
    Bingo was his name-o
    ITCB
    Aug 2010
    264
    I rigged it to my battery and got 12 volts through it when it clicked on. Didn't want to check for continuity on a hot wire. Looks like it has a diode in as well. Two copper prongs, two brass. I did positives to copper. Have to run and get up into the mountains, probably overnite. Thanks; I trust you more than the manual. GB
    Aug 2010
    264
    Okay, I think it is coming together. Diagnostically speaking. The relay was functional with nice little sounds produced. But I believe the diode in the starting circuit relay is going out- gone- which is letting juice backfeed so the neutral light comes on dimly with the clutch squeezed, the kill switch won't kill and the start button does not start. I have the kickstand switch by-passed. The neutral light works well for its purpose, but at night it can be seen glowing dimly all the time. Am I making sense? GB
    Aug 2010
    264
    Update--
    I bought a used starting circuit cut-off relay from a 'good running bike' and it starts my bike with the button beautifully, but I have still have
    the neutral light on, especially with clutch, and no kill switch. I can't imagine it isn't another bad diode letting electricity go both directions.
    A full refund awaits. But perhaps I have not thought of something else? This diode is located just above the neutral light in the diagram ptmg sent above.
    Thanks, GB
    918
    Faulty neutral switch? Can you get an ohm/continuity reading across the open neutral switch? Maybe corroded connections within the switch allowing a small leak of current in the open position.
    Sold bike.
  1. Flasher relay ID
    By chevyy1212 in forum General Discussion
    Last Post: 04-01-2012, 10:16 AM
  2. what is this relay?
    By zoolander in forum Technical Help
    Last Post: 03-04-2012, 07:49 PM
  3. Clutch relay i think
    By ziggy in forum TW200 Classifieds
    Last Post: 01-20-2012, 10:38 PM
  4. pilot circuit
    By mike m in forum Technical Help
    Last Post: 08-30-2011, 02:37 PM
  5. Private Messages and New forum
    By brownie2 in forum General Discussion
    Last Post: 09-20-2010, 08:55 PM
02 r1 starter cricuit cut off relay
roadstar starter cut off relay
starter circuit cutoff relay
starter cut relay clicking
starting circuit cut off relay
starting circuit cutoff relay yamaha
testing a safety relay switch on yamaha r1
what does a starting circuit cutoff relay do
wireing diagram for 2001 yamaha ttr 225
yamaha beartracker kill switch relay
yamaha starting circuit cutoff relay
yamaha ttr 225 how do i know the starter relay bad
