tachometer?
Results 1 to 7 of 7
Thread: tachometer?
    Member sakogu's Avatar
    Penticton, BC, CANADA
    64
    does anyone know if its at all easy to install a tachometer to a 1990 tw 200? im kinda used to having one and miss it... thanks
    Member poweber's Avatar
    Aug 2010
    Hellertown, PA USA
    86
    No problem with a Koso Tach - another member recommended it to me a it took all of a hour to install. Simply remove the seat and gas tank, connect 4 wires frorm the tach harness; one to the ignition via a supplied splice, two to the battery terminals, and one to the coil with an included splice. Reinstall the seat and tank (for a longer and more comfortable ride) and VOILA! The programming of the tach is MUCH more difficult and poorly documented, but included,so check out this thread with photos from the old Forum. I could not find a way to upload my photo from this machine at work.
    http://tw200forum.co...0/ShowPost.aspx
    Koso web site is http://www.kosonorthamerica.com/
    and the model we installed is the BA481B17 for $114.95.
    And holler if you need more help. Real nice instrument!
    Happy Trails,
    capt pow!
    2010 TW200, factory rear rack, Chinese jumbo footpegs, Jimbo windshield, ScalaRider G4, Clarke 2.7 Gallon tank, Koso tachometer, Stearns seat cover, gel grips, Dirtly 1" handlebar risers, Osram Rallye H4 bulb, Cortec Deluxe rear bag .
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    I used a product called tiny tach. As I remember they make ones that refresh every 2 seconds or every 1/2 a second. Also doubles as an hour meter. I'll try and take a picture of it later today on the bike. Bought from a website involed with DR650 mods I believe. It came with a nice anodized alum for the handle bar bracket. Looks like this product.
    http://cgi.ebay.com/TINY-TACH-HOUR-M...efaultDomain_0
    I have them on both my tw and my ttr250
    Hope that helps
    Josh
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
    1996 TW200 Edmonton, AB
    590
    A few of us have installed a Trailtech Vapor. Tachometer, speedometer, trip meter, engine and outside temp, etc.
    A big advantage for me is that the speedo can be calibrated correctly, my stock one was reading quite a bit low.
    So far I just have the speedo hooked up, when I finish I'll pull the other instruments for a GPS and a voltmeter.
    Price w/o the turn signal unit is 129.95.
    http://trailtech.net/vapor.html
    Acewell also makes similar combo units.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Also look at the Trailtech TTO tachometer.
    Senior Member jckosnow's Avatar
    Sep 2012
    Maine
    177
    PJung, I want to see your tdub go 140! my 2012 stock spedometer only goes to 85
    2012 TW200, 1993 KLR650, 1992 GSX750F
    Pleasanton, CA
    5,721
    metric bikes must be faster because 140 kilometers per hour = 87 miles per hour
  1. Tachometer
    By RTG in forum Performance and Customization
    Last Post: 10-24-2012, 03:55 PM
  2. Tachometer?
    By Woodi23 in forum General Discussion
    Last Post: 09-18-2012, 04:48 AM
  3. Battery discharge = dead tachometer
    Last Post: 06-11-2012, 06:43 AM
  4. Trailtech tachometer install....info needed.
    Last Post: 03-17-2012, 05:27 PM
  5. What years had a tachometer?
    By motorhead in forum General Discussion
    Last Post: 05-28-2011, 11:01 PM
info techometer net
installing tachometer on yamaha tw200
tach voltmeter
tachometer hour meter
tw 200 tachometer
