front sprocket
Results 1 to 10 of 10
Thread: front sprocket
    Junior Member JMFLH's Avatar
    Aug 2011
    Tallahassee, FL
    6
    I recently changed the front sprocket on my 2007 TW200 and wanted to know if it's normal to have a small amount of play in the sprocket? The two sprocket retaining bolts are tight against the retaining clip but the sprocket moves a very small amount right to left.
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    Quote Originally Posted by Jim Shayeb View Post
    I'm not sure what the actual spec is on this, but I changed both of my sprockets today and I noticed the same thing. My bike only has 2500 miles on it, so I doubt that it is too far out of spec. Also, I tried moving the sprocket outside of it's run position on the output shaft splines and it felt the same all along the splined portion.
    Senior Member tripleted's Avatar
    B.C.
    136
    I changed mine and it was very tight to go on to the shaft and tighted up tight with the bolts. I loctighted the bolts with medium strength locktite. 500 miles on the 2006 TW.
    Senior Member Sly Fox's Avatar
    Oct 2010
    Wiltshire, UK
    203
    It is normal for this type of sprocket fitment to be lose and a bit wobbly.
    It doesn't hurt the shaft splines because they are much harder than the sprocket.
    Always use non permanent thread lock and consider using new bolts because they are tiny on the TW and won't like being re-torqued dozens of times.
    We're in 'Bat Country' now....
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    Mine wiggles too. As SlyFox suggested, buy new bolts. M5x10mm. And don't over torque them like I did and ruin a perfectly good sprocket.
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    Aug 2011
    Tallahassee, FL
    6
    Quote Originally Posted by sorethumb View Post
    Thanks for the replies. My 2007 TW 200 only had 395 miles on it when I recently bought it. Thanks to this forum I re-geared it much taller than most on this forum. I now have a 16/47 combination that's great for my paved road riding. I wanted to be able to cruise comfortably around 50-55 mph. I used the gear calculator to arrive at my present gearing. Street tires are next. This bike is simple to work on and so far I'm enjoying it.
    Aug 2011
    Tallahassee, FL
    6
    After changing to 16/47 tooth sprockets I got 82.6 miles per gallon at 50-55 mph. Very happy with the gearing change. Help from this forum provided the information to arrive at this gearing. I bought my 15/47 sprockets and o-ring chain at Lytle Racing Group. They were great to deal with. After one week I contacted Lytle again but they didn't have a 16t front sprocket. I found a 16t at PBI which is an American made sprocket. Highly recommend both Lytle and PBI! I'm now looking at tires, probably will go with the Shinko SR428 since I'll ride 99% of the time on paved roads.
    That sprocket isn't ruined. Simply start drilling the bolts from the other side. Odds are the heat and vibration will spin those shanks right out. If not, an EasyOut will spin the drilled shanks no problem.
    BC
    623
    I see BLUE Loc-tite in there...should've been GREEN!
    2008 TW200
    Southwest corner of BC Canada
    Apr 2011
    Martinsville Indiana
    2,089
    My front sprocket has a little play also. I just about took the side case of before I seen this thread.
  1. Front Sprocket
    Last Post: 09-30-2012, 07:46 PM
  2. Front Sprocket
    By old betsy in forum Technical Help
    Last Post: 09-01-2012, 04:07 AM
  3. Front sprocket
    Last Post: 07-20-2012, 06:54 AM
  4. Front sprocket issue
    By SRTeric in forum Technical Help
    Last Post: 06-07-2011, 11:36 AM
  5. Front sprocket noise?
    By Little Valy in forum Technical Help
    Last Post: 10-14-2010, 10:05 PM
a 16 front sprocket on yamaha tw200
pbi circle clip sprocket retainer
tw200 front sprocket
yamaha warrior sprocket retainer clip
