Another Front Drum Brake Question
Results 1 to 10 of 17
    Senior Member FnMag's Avatar
    493
    I searched and read all the threads I could find.
    I have a brand new cable and brand new pads on my front drum brake. I just got it back from the shop today ( they put new rear tire tube on as well as did the front brake).
    It has to be fully adjusted tight to get any kind of braking power and even then, it's iffy.
    I put bike on my big Coca-Cola plastic crate/ bike stand and I can do the spin and listen thing and cant get them to go shhh-shhh-shhh sound. Does it sound like they mucked up ? or should I pop the drum off and check the inner drum surface?
    Ephrata, WA
    1,125
    I took off my brake cam arm (the arm that the brake cable goes to and is connected to the outer drum via a splined shaft) and rotated it a couple notches forward. Then I adjusted my cable. It has worked for me.
    1990 TW200
    Desert, SoCal
    7,369
    New cables will stretch initially, work for zillions of miles then start stretching again when near death.
    493
    I moved the arm a bit and it satisfactorily stops now. I did the QWERTY shh-shhh-shhh thing and after riding around the back neighborhood culdesacs that have no houses built yet I brought it back and checked again. Very slight "sh"
    YAY for the forums, they came back through again !!
    Thanks fellas !
    Senior Member GlassAnkles's Avatar
    KS
    116
    i had to move the arm also, good to know others did. i didn't say anything because i bought Tusk brake shoes for 9.99
    11 ninja 1000
    493
    Oh, this is the first riding I've done on my TDub in a while and even though it was just around the culdesacs and in the open field where there would be houses if any houses were built I keep asking myself if I should sell my Shadow..
    493
    Quote Originally Posted by GlassAnkles View Post
    Mine came from ebay. Tusk also and cheaper than stadium yamaha.
    I had to realign my rear brake lever. Original shoes and still have half the lining to go. I don't use the rear brake very much. Danged rear brake will kill you. It lock up, cause a slide, and dump you in a heartbeat.
    Desert, SoCal
    7,369
    Single leading shoe brakes don't have a lot of material contacting the drum til they get bedded in as well. Only one end of the shoes expand when the brake is applied. So with new cables and new shoes you could be somewhat brakeless for quite a few miles.
    493
    Quite a few meaning 100, 250 or more? It felt good yesterday, after the arm adjustment. Another 30 minutes I could have gotten it to where the lever adjustment was more than halfway out (it's just a tad over half way) and I could of moved the arm more, but it's such a pain in the rear to get that arm back on the splined shaft.
    Oh, I hit 6k on the odometer too!!
  1. Front brake '99 - '01
    By dutchbat in forum Technical Help
    Last Post: 05-25-2013, 05:46 AM
  2. Spokes for drum brake hubs
    By Return of the Cafe Racers in forum Technical Help
    Last Post: 05-22-2013, 05:05 PM
  3. Trailtech vapor on a drum brake (pre-2001) bike
    By jontow in forum Performance and Customization
    Last Post: 03-02-2013, 05:59 AM
  4. WTB - Front brake hub for drum brakes
    Last Post: 12-27-2011, 08:26 AM
  5. Replies: 1
    Last Post: 09-20-2011, 07:06 PM
front drum size
tw200 drum brake pads
tw200 forum drum brake adjuster
tw200 front drum brake
tw200 improve front drum brake
