coasting enricher hose
Results 1 to 8 of 8
    Junior Member TWhog's Avatar
    Sep 2011
    6
    where does the loose end of the hose connect?
    918
    3rd picture down is your answer. The below link is within this Technical Help forum, 2nd post down.
    https://tw200forum.com/index.php?/top...dentification/
    Sold bike.
    Sep 2011
    6
    I guess the hose just dangles down and is open to the outside air?
    I called the local Yamaha dealer and they told me it should be attached ti the intake manafold somewhere and it needed a vacume to opperate the coasting enricher???
    Sep 2011
    6
    I think I see now. It is not a coast enricher hose at all. Its a vent for the float bowl. Sorry for taking up your time. Thanks
    Member TrailWhale's Avatar
    2007 FZ6 Lancaster, PA
    46
    Out of an abundance of caution, during my most recent work on the carburetor (think ethanol problems) I routed this hose virtually straight up in the air and ty-wrapped the end of the hose to the rear gas tank mount. Seems to me that should preclude this hose from sucking water on my next stream crossing, so long as it's less than tank deep! Obviously if this hose does suck water the engine will probably stop running in short order. And the normal routing - straight down, to a point below the swing arm - certainly permits it to suck water very easily. (I'm sure I read this tip somewhere in this great TW200 site.)
    - - - Happy stream fording, Jim
    Most problems can be solved with a suitable application of throttle!
    2007 Yamaha FZ6 bagger (still miss the TW200)
    2001 TW200 Yuasa YTZ7-S + Tender Jr.; fuel filter; socket head cap screws for seat; homemade rear rack; D2Moto; carb mods (#128; 3x.01; 2-1/2 turns) (sold 2012)
    1993 XT350 (sold)
    1987 TW200 14/55+Oring (sold)
    et al, et al, starting with 1964 Honda 50 Sport
    Desert, SoCal
    7,369
    Quote Originally Posted by TrailWhale View Post
    You need both an upward and downward vent if you're gunna do that. If you drop the bike it'll get fuel in the vent line and not only won't start but it can burn the bike to the ground. Somewhere in this mess I did a writeuip on installing tee'd vents.
    Ok. Here it is:
    https://tw200forum.com/index.php?/top...h__1#entry5576
    46
    Thanks for the insight, lizrdbrth. I read the older article you referred to, can appreciate your observations, and will be replumbing my installation shortly. I apparently have a newer style carb (2001) with only a single vent hose attached to the coasting enricher (the float chamber drain hose doesn't count since the float chamber drain valve is normally closed). Since I've already tied the existing carb vent hose way up under the fuel tank, I'll just add a fuel filter to the open end of that line, and then add the necessary "tee" and another vent line routed back to the original location down by the swingarm. Seems to me that being able to ford streams at "carb depth" should certainly suffice. If I occasionally need a few extra inches of "clearance", by leaving the carb vent line routed to the swingarm a little extra long, I should be able to temporarily lift/tie up the end of that vent line, and put it back in place as soon as I cross a deeper stream (saving the trouble of remembering to open/close a valve). Again, thanks for a great article on this topic.
    - - - Happy Trails, Jim
    1993 XT350 (sold)
    Desert, SoCal
    7,369
    Put a shutoff on the lower line if you wanat to submarinate . Get one of those tiny 1/4" drip irrigation shutoffs. I think mine were less than a buck.
  1. fuel hose routing
    By bikerjosh in forum Technical Help
    Last Post: 02-18-2013, 04:24 PM
  2. Coasting Enricher
    By dakman74 in forum Technical Help
    Last Post: 04-02-2012, 09:42 AM
  3. Coasting Enriching Diaphram Bad
    By DBuck42 in forum Technical Help
    Last Post: 10-23-2011, 06:31 PM
  4. Battery breather hose
    Last Post: 07-06-2011, 06:12 AM
  5. Weird carb hose
    By 805gregg in forum Performance and Customization
    Last Post: 11-20-2010, 08:41 PM
1987 yamaha tw200 vent carb hose
1998 yamaha tw200 fuel and vent hose routings
1999 yamaha tw200 carberators hoses
2001 yamaha tw200 carburetor air vent hose joint
tw200 carb vent hose mod
tw200 carb vent tubing
tw200 fuel hose
vent hoses from carb on yamaha tw 200
vent line routing 1993 yamaha tw 200
yamaha trailway carburetor hose routing
