TW won't start
Results 1 to 2 of 2
Thread: TW won't start
    Junior Member Vlakslee's Avatar
    Mar 2011
    16
    Need some advise. My TW gets ornery when I let it die BEFORE fully warming up. It won't start again until it sits for 20 min or so. Anyone have any tricks for getting it started? I pull the choke out and it still won't start. It's like it gets flooded. Is there anyway to spray some starting fluid? Or just wait it out?
    Senior Member JarrodWeaver's Avatar
    Austin, Texas
    112
    Quote Originally Posted by Sierra Rider View Post
    Definitely DO NOT use starting fluid!!! You need to systematically troubleshoot your no-start problem. Starting fluid will simply create a new (much larger) one. If an engine turns over the problem is either fuel or spark. I would start with the fuel/carb since it is the most likely culprit.
  1. Start but no start - please help -
    By rtf in forum Technical Help
    Last Post: 05-23-2013, 08:24 PM
  2. Won't start but will???
    By Lido in forum Technical Help
    Last Post: 09-12-2011, 07:37 PM
  3. TW no start
    By immgunn in forum Technical Help
    Last Post: 07-03-2011, 07:28 PM
  4. kick start won't start
    Last Post: 01-15-2011, 05:23 AM
  5. TW won't start?
    By rolo in forum Technical Help
    Last Post: 10-28-2010, 05:05 PM
