Oil Change completed
Results 1 to 8 of 8
    Member HDLLLIII's Avatar
    Aug 2011
    32
    Many thanks to the posting on changing the oil. I did loosen the srcew on the head to verify top end lubrication. Wow what a mess. I loosened the screw of couple of turns, nothing...couple of more, nothing, took it all the way out, oh yeah! we have oil flow to the head, dang what a mess. I do have it all cleaned up now, ready for more riding. These darn newbies have to learn the hard way. Again Thank You all for this forum and all the expierience, with very helpful tips to keep the my machine running perfectly.
    Aug 2011
    Cayce, SC
    3,109
    Been there... I also stripped the phillips head on the bolt and got really pissed until I realized I could just use a socket or wrench. I really am an idiot sometimes. LIVE AND LEARN
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    I agree with your sentiments regarding the tech help resources on this board. It's one of the things that makes this place so great.
    I wonder if there is a way to make a "sight glass" or small sight tube that one could screw into that port merely to verify oil flow without the mess, them remove and plug with the original screw once flow has been confirmed?
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by sorethumb View Post
    I think the idea is to bleed air out of the system as well as verify top end flow. Probably best to just put up with the mess.
    Stephen S.
    '07 TW200:
    When I do an oil change I don't mess with the screw. Just start the bike and let it idle a few minutes before riding off.
    866
    Same here. If my engine blows up, I'll let everyone know.
    BC
    623
    I'll take the screw right out, then start the engine and have my finger at the ready...as soon as oil flows, I plug it with my finger and hit the kill switch.
    Done!
    2008 TW200
    Southwest corner of BC Canada
    Desert, SoCal
    7,369
    Pull the plug wire, put your finger over the hole and spin the starter til there's oil.
    I've become as jaded as Qwerty about this.. One day it's gunna bite me in the butt. lol.
  1. Double TW Iron Butt Saddlesore completed.
    By lizrdbrth in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-11-2016, 11:16 PM
  2. high fender mod completed
    By crjanow in forum General Discussion
    Last Post: 01-04-2013, 06:49 PM
  3. Lucky Peak Fall Loop Ride - Completed
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-29-2011, 10:15 AM
  4. Pearl Ride (Completed)
    Last Post: 09-29-2011, 12:49 AM
  5. Dry Buck TW200 Completed
    Last Post: 07-24-2011, 09:41 PM
tw 200 oil fill port
tw200 yamaha 2011 how to change oil
