cam sprocket removal
Results 1 to 8 of 8
    Junior Member Mongo357's Avatar
    Aug 2010
    16
    Hello,
    I need some advice. I'm replacing the base gasket on my '05, and I'm stuck at removing the cam sprocket. This thing is seriously locked up - no rust or anything catastrophic like that, it just won't come loose. Is it a standard right-hand thread? Would just like to be sure I'm doing the right thing before I start really cranking on it.
    Thanks
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Right hand thread. Tap it a few times with a hammer. That might pop the friction lock.
    Or if you can get help, tap with hammer while applying torque with the wrench.
    Stephen S.
    '07 TW200:
    Aug 2010
    16
    Quote Originally Posted by srs713 View Post
    Ok, thanks!
    I skipped the timing chain a couple teeth already on the crankshaft sprocket. I reinstalled the tensioner (why do the directions say to remove that first?) I'll have to check the crankshaft sprocket to see if I damaged any teeth. (fingers crossed)
    Aug 2010
    16
    I've hit the bolt with over 70 ft-lbs of torque, and it's not budging. Am I missing something? Is there some kind of locking device? If I just need more torque, then 1) I'm worried about damaging the timing chain, and 2) I'll need to come up with some way to hold the bike down!! I'm almost enough torque to lift up the rear wheel...
    Next step is a hand impact and a 6-point impact socket.
    Jul 2011
    1,123
    Be prepared to replace the bolt when you finally get it out. When I removed and replaced mine, the bolt started to fail as it was being reinstalled, and if I had not felt it "getting weird" at a low torque, it would have REALLY sucked to get out when it broke off. These things must be torqued almost to yield point when installed.
    ITCB
    Aug 2010
    16
    Quote Originally Posted by operose View Post
    The hand impact tool did the job. I'll put that on my list...
    As for torqueing this bolt to the point on yield, I thought it was supposed to have 42 ft-lbs! That is no where near yield, if it were I would have sheared it easily trying to remove it.
    Jul 2011
    1,123
    Mine didn't come out hard at all, but with hardly any torque when reinstalling it started to twist off.
    No clue, but glad you got it apart.
    ITCB
  1. Air box removal
    By neimang in forum Performance and Customization
    Last Post: 09-18-2014, 01:17 PM
  2. Air box removal
    By neimang in forum Technical Help
    Last Post: 06-21-2013, 10:27 AM
  3. Replies: 0
  4. Cam Collar Removal
    By ryderg in forum Technical Help
    Last Post: 05-18-2011, 09:49 AM
  5. sprocket sidecover removal question
    By tripleted in forum Technical Help
    Last Post: 01-06-2011, 06:54 AM
01 tw200 cam sprocket torque specs
cam bolt torque for bw 200
how to loosen yamaha cam sprocket bolt
removing cam yamaha 200
