Help, Spokes, Help!
Results 1 to 10 of 20
    Member retro's Avatar
    82
    OK, I wanted new front & rear spokes for '87 TW. Took pics of the old ones. Ordered new ones & put the back ones in, no problem. Now the problem. The front spokes are 2 different lengths with 3 different hooks. I have tries several ways, using my pics but they do not seem to work right. Does anyone have any suggestions or do I have to buy another '87 just to look at the spokes?
    Thanx Much!
    Retro
    Desert, SoCal
    7,369
    Sounds as if you have the spokes for a disc brake wheel. All the hook ends on disc wheels face the outside of the wheel, while on drum wheels they alternate, inward and outward facing.
    Basically drum brake spokes are bent at a 90 degree angle and disc spokes are on the order of 45 degrees.
    I'll be stripping a front wheel next week. If you can't figure it out or can't get the right spokes and can afford to wait, I'll bundle them up and you can use what you need and ship the rest back.
    Senior Member Bagger's Avatar
    Jan 2011
    Central WA
    1,050
    Quote Originally Posted by retro View Post
    Thanx Much!
    Retro
    Ha! Nice try retro, if you wanna buy another bike, you don't have to come up with weak excuses, just buy it!!
    Good On you LB, your a good Man.
    Bag
    "The TW may be slow, but the Earth is patient" - MK
    "If I'm wrong, and it turns out that you hate it, I'll send you all my Barry Manilow albums." LB
    82
    82
    Thanx Much LB,
    I have this bike down into parts. Re-painted everything. Am going to brat it. I need to get the wheels on to put the motor back on. If I can't figure thes spokes out, I may just put plywood inside of the rim for spokes. That would look good if I paint it.
    Thanx Much!
    Retro
    82
    Found my old spokes & compared to the new ones. Everything is the same. I am just putting in wrong I guess. I will keep trying.
    Retro
    Pleasanton, CA
    5,722
    Hi Retro,
    I have a front wheel with the drum brake. Would it help you to have some pictures of an intact wheel/hub/brake drum with spokes? If so, let me know what views would be the most helpful and I can take some pictures for you.
    Brian
    82
    Hello Brian,
    I am putting my long spokes on the big hub. Can you measure one of your spokes on the big side of the hub? Am I putting the right spokes on the right side of the hub?
    Thanx Much!
    Retro
    Pleasanton, CA
    5,722
    I will check after I get home this evening and let you know.
    Brian
    Pleasanton, CA
    5,722
    Hi Retro,
    It looks like the long spokes (approximately 8") are laced into the smaller wheel hub and the shorter spokes (approximately 7.5") are laced into the larger brake drum. See picture below:
    I hope this is helpful.
    Brian
  1. Aluminum & steel rims, stainless spokes?
    By retro in forum General Discussion
    Last Post: 06-26-2017, 10:56 PM
  2. Spokes for drum brake hubs
    By Return of the Cafe Racers in forum Technical Help
    Last Post: 05-22-2013, 05:05 PM
  3. WTB Rear Wheel Spokes
    By Lonesome Dave in forum TW200 Classifieds
    Last Post: 02-25-2013, 12:27 AM
  4. Free rear spokes
    By lizrdbrth in forum TW200 Classifieds
    Last Post: 01-22-2013, 01:32 PM
  5. Spokes Torque?
    By FlyinHawaiian in forum Technical Help
    Last Post: 10-22-2010, 04:32 PM
lacing spokes yamaha tw 200
