Clutch slipping!
Results 1 to 10 of 11
    Junior Member AttitudeXX's Avatar
    Aug 2011
    6
    So I have a 2006 tw, fairly stock, used with 2000+ miles off road on it. A woman had it before i got it and i think that she may have been riding the clutch a lot. when on the highway in 5th gear I can feel the clutch slipping a lot... I already loosened the clutch cable so that it wouldn't put any force ont he plates but it still isn't better. Should I (could I even) tighten the springs on the clutch? What about new clutch plates? Where can I get these if i need to get a new assembly or plates?
    Desert, SoCal
    7,369
    OEM seem to be the best choice. Fait number of complaints concerning Barnett et al.
    What kind of oil? Any oil labeled "energy conserving" has additives to make it slipperier than normal. These additives collect on the fiber material of the clutch and let it slip. First oil change I did on Tdub I used Castrol GTX, and within 50 miles the clutch slipped like crazy. Switched to Valvoline 4-stroke for motorcycles with wet clutches and after a few hundred miles bite improved, but the clutch was never right again. About 15,000 miles later it started slipping again, so I switched to a XT225 clutch with Barnett plates and springs. Yes, a Barnett will drag a little when cold, but almost 32,000 miles on that clutch and still performs as well as when new.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Hello,
    Have you set (setting) the lever mechanism ?
    Poway CA.
    2,100
    When I went from a TW 196cc to 226cc I used Barnett Clutches in a TW clutch basket and it slipped when under a load. I installed some shims under the springs and that stopped the slipping problem.
    The Barnett Clutches do drag a little when cold and have less fiber surface than stock, surprised me when I saw that.
    I may go back to stock clutches in the TTR basket with shims in the new TW 245cc.
    Shim pics.
    The shim is to the left of the spring and in the other pic on the spring mount ready for the spring.
    Ronnydog
    What springs did you use with the Barnett clutch? What was the free length? Did you also use new steels, or reuse your old ones?
    Poway CA.
    2,100
    I used Barnett Springs, free length I did not ck but they are slightly longer than stock, yes new steels.
    Ronnydog
    Weird!
    Aug 2011
    6
    Oil was changed by dealer, would have to ask them to find out what kind of oil was used.
    Aug 2011
    6
    Quote Originally Posted by christddel View Post
    Hello,
    yes
  1. Slipping clutch...????
    By rastaman in forum Technical Help
    Last Post: 07-29-2013, 11:09 AM
  2. Slipping Clutch
    By yawabala in forum Technical Help
    Last Post: 01-14-2013, 07:44 AM
  3. Another Slipping Clutch
    By FnMag in forum Technical Help
    Last Post: 06-07-2012, 09:21 AM
  4. clutch slipping
    By dubstep in forum General Discussion
    Last Post: 02-03-2012, 11:57 PM
  5. slipping clutch
    By tpar1220 in forum Technical Help
    Last Post: 10-01-2010, 10:37 PM
225 clutch install
tw200 5th gear slipping
tw200 clutch slippage
tw200 clutch slipping
tw200 clutch slipping 5th gear
tw200 forum cluch slip
xt225 slipping clutch
yamaha xt225 clutch slipping
