Handlebars
Results 1 to 7 of 7
Thread: Handlebars
    Member Lido's Avatar
    Sep 2011
    64
    Hi everyone! Just wondering how much of a riser can I put on the bars before I have to start lengthening the cables. Does anyone think 2" will be an issue?
    918
    PowerMadd sells a 1.6" rise. It works without extensions and makes the bike a lot more comfortable. 2" should be possible, you just may need to re-route cables a little bit.
    (double check your bikes measurements with what the description says) https://www.denniskirk.com/powermadd...prd/595502.sku
    There are more expensive options that rise and tilt, but if you don't want to extend the cables I'll assume you are looking for the cheaper option.
    Sold bike.
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    I changed to ATV high bars, they are at least 2" higher and have a better pull back, I used the same bars on my V-Strom 1000, they help alot, the cables fit with some finesse.
    Senior Member Bagger's Avatar
    Jan 2011
    Central WA
    1,050
    2" Moose racing risers here, cable length not an issue, even with the handguards. Not sure you could go much more than 2 though.
    Bag
    "The TW may be slow, but the Earth is patient" - MK
    "If I'm wrong, and it turns out that you hate it, I'll send you all my Barry Manilow albums." LB
    Senior Member yamamont's Avatar
    Sep 2011
    North of Seattle
    172
    I also have ATV bars. It was a bit tricky getting my throttle cables sorted out. The cable now run below the handlebar. They work fine but I had to get them just right for proper throttle return. Works great now and what a difference when standing up in the techy trails. The bars had a much thicker wall than the stock bars as well.
    2-inch risers are good. Changing to wider bars at the same time is a no-go.
    Oct 2010
    572
    I love the taller wider bars, makes it more of a motorcycle than a toy.
  1. TW200 HANDLEBARS
    By Moose in forum Technical Help
    Last Post: 06-03-2013, 04:49 PM
  2. Tusk t-10 handlebars Sale
    By RainWillFall in forum Performance and Customization
    Last Post: 03-07-2013, 05:41 PM
  3. Banshee Handlebars
    By Kirk Ross in forum Performance and Customization
    Last Post: 02-28-2012, 06:17 AM
  4. Handlebars
    By TeeDubs in forum General Discussion
    Last Post: 01-27-2012, 07:47 PM
  5. new handlebars
    By 805gregg in forum Performance and Customization
    Last Post: 11-19-2010, 06:11 PM
