installing Bridgestone TW203/204's difficult?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree1Likes
Thread: installing Bridgestone TW203/204's difficult?
    Senior Member GlassAnkles's Avatar
    KS
    116
    before i break out my tire irons and baby powder, is this going to be the same struggle as a dirtbike? i could swap 21/18's pretty easily. gave up on a 19" rear ktm wheel one time and took it to my dealer
    im nervous because its not hot outside anymore, so i don't know how warm i can get these new tires before the install
    thanks
    11 ninja 1000
    Senior Member TWBARR's Avatar
    Jul 2011
    IN
    186
    Quote Originally Posted by GlassAnkles View Post
    thanks
    I just recently installed my shinko sr428s which is also like the 203/204s. It was a bout 65 degrees outside when we installed them. I didn't have any tire spoons so i toke some cheap box wrenches and ground them into a homemade tire spoon. Then with my dads help we used some dawn soap and water and worked them onto the rims. Just be extra cautious of the tubes. Rear tire was the hardest but we used little movements.
    Devon, England.
    614
    My tyre changing skills are poor at best, but I can do TW203/204's alright.
    Remember to put a little air in the tube before you put the second side of the tyre on the rim. This helps reduce the risk of pinching the tube, and use plenty of soap or even hot water will help.
    Jul 2011
    IN
    186
    Quote Originally Posted by uktw125 View Post
    +1
    KS
    116
    the front was the easiest tire ive ever installed, the rear was a horrible experience. the rusted up bead on my 87's original tire was a killer to pop. finally got some 6" C-clamps and busted it off
    11 ninja 1000
    Devon, England.
    614
    But you did it.
    866
    I would file that under "the joy of old motorcycles", as opposed to a TW specific hardship. BTW, the easiest way to break the bead is to run over it with the Corvette.
    KS
    116
    Quote Originally Posted by Rodney View Post
    i actually put a 12 ton bottle jack on the tire, then pressed it up against the frame of our 4wd dodge ram, lol. it still wouldn't budge
    DaveF likes this.
    11 ninja 1000
    KS
    116
    a final photo to kill this thread, looks killer, and the all balls wheel bearings are rolling smooth
    11 ninja 1000
    Member ktrout01's Avatar
    Bristol, CT
    80
    Both tires took less than a six pack.
    1989 TW200
    2003 Triumph Bonneville
    2003 BMW F650GS
    Any commander who fails to exceed his authority is not of much use to his subordinates.
    Arleigh Burke
  1. BRIDGESTONE TW203-204 TIRE PRESSURES
    By thumper in forum Technical Help
    Last Post: 10-30-2013, 07:53 PM
  2. FS Pair of used Bridgestone tw203 tires WA
    By snakefoot in forum TW200 Classifieds
    Last Post: 04-10-2013, 01:15 AM
  3. New Unused Bridgestone TW203 & TW204
    By papa wheelie in forum TW200 Classifieds
    Last Post: 09-15-2012, 08:45 AM
  4. SOLD Bridgestone TW203 & TW204 brand new, sell/trade
    By Loppy in forum TW200 Classifieds
    Last Post: 08-13-2012, 11:58 AM
  5. Installing AfterBurners
    By Rohnsman in forum Performance and Customization
    Last Post: 12-25-2010, 06:42 AM
tire install
