Which way to take off back axel nut?
Results 1 to 10 of 17
    Senior Member ceramite's Avatar
    Sep 2011
    Baltimore
    160
    My dad is over and we are trying to adjust the chain, but the back nut is frozen on. Any hints? It is left to loosen, correct?
    It looks like there is a black metal ring around the bolt inside the nut.?
    Thank you!
    918
    It's the usual lefty-loosy, righty-tighty. Use a 6-point socket and put some muscle into it
    Sold bike.
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    dont just put a bunch of muscle into it. on my TW the nut dont have much to grab onto and you dont want to round it off. DONT USE A ADJUSTABLE WRENCH! if its that tight use some WD40 and wait for it to come free.
    Sep 2011
    Baltimore
    160
    Thank you guys!
    What a crappy day, my dad is good guy but he was worried about breaking something so we didn't adjust the chain or change the oil. It is good that we didn't snap anything. The bike is a 2007 and I don't think the oil has been changed once, and the chain has at least 4 inches of slack! We used some WD40 and lightly bumped/hammered (using the dog bone wrench in the bike kit) the two bolt and both wouldn't nudge.
    Cleaning the oil filter was a snap.
    So I am going to take it to the dealer. I am just bummed that the scheduled manly afternoon was a washout.
    Anyone know a good place in Baltimore? I have read horror stories about Pete's.
    918
    Quote Originally Posted by ceramite View Post
    Thank you guys!
    Let the WD soak in. Apply it a couple times a day for a couple days and try again. Use the correct tools (NOT the dog bone wrench) and you can put muscle into it (I'll repeat, 6-point sockets). It's been in that same position for quite some time if you have 4 inches of slack and will take some work to break it loose.
    If you don't mind spending the money, take it to the dealer. But I'd recommend getting the proper tools and doing it yourself. Why? Because you will need a new chain by the sounds of it and therefore new sprockets as well. Changing that stuff out yourself gives you a better understanding of your bike and how it works.
    Sold bike.
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    Don't bum out; give it the WD-40 or equal, take it to your friendly tire shop and have them get on it with a pneumatic metric wrench. Loosen it down to where you can take over. Go home and finish it.
    Sounds pretty bad- any chance there is a piece of cott6er- pin in it or some such?
    Might have an extra axle. ---GB
    Aug 2011
    Cayce, SC
    3,109
    I use a 1/2" impact wrench every time. Super easy and makes adjusting the chain a 2 minute job. I picked mine up at autozone for around $60.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Desert, SoCal
    7,369
    Is there a cotter pin or parts thereof in the axle hole?
    Jul 2011
    1,123
    Agreed on the checking for a chunk of cotter pin binding the castle nut.
    Also, WD40 is an awful substitute for penetrating oil like PB Blaster
    ITCB
    Castle nut? On a TW?
  1. How does this go back in?
    By Tirebiter in forum Technical Help
    Last Post: 02-22-2013, 04:12 PM
  2. I'm back!
    By Bucknutz in forum General Discussion
    Last Post: 01-22-2013, 05:12 PM
  3. I'm Back!
    By nz6e in forum General Discussion
    Last Post: 10-30-2012, 08:38 PM
  4. Looking at getting back on a TW
    By chickenwingsmmm in forum General Discussion
    Last Post: 09-07-2012, 04:52 PM
  5. I'm almost back, i think...
    By weather_man in forum General Discussion
    Last Post: 05-22-2011, 05:52 AM
