Coasting Enriching Diaphram Bad
Results 1 to 2 of 2
    Junior Member DBuck42's Avatar
    Oct 2011
    14
    I posted this question on another thread, but thought maybe a separate thread would help get a quick answer.
    If the coasting enriching diaphram is cracked will it cause the engine to run ONLY with full choke and stall when the slightest bid of throttle is applied? Thanks for all the help you guys/gals provide to folks like me that have little experience working on motorcycles. You guys/gals are helping to save me alot of money.
    Dennis
    Beats me. Is yours messed up?
    Usually an engine that only runs with full choke is running way lean. Check for fuel flow to the carb, and if that is good, time to go into the carb.
  1. Coasting Enricher
    By dakman74 in forum Technical Help
    Last Post: 04-02-2012, 09:42 AM
  2. coasting enricher hose
    By TWhog in forum Technical Help
    Last Post: 09-28-2011, 09:16 AM
