Valve clearance
Results 1 to 4 of 4
Thread: Valve clearance
    Junior Member shady145's Avatar
    Aug 2010
    4
    I am working on restoring a 1996 Yamaha tw200 after its sat stored improperly for six years. Every thing appears to be in order other then what appeares to be a gas oil mixture entering the air box. I have disassembled the carb and cleaned it and do not belive it to be the culpret. My next move was to adjust the valve clearance but cannot find the right gap amount for the model year. I have only been able to locate manuals for models made after 2000. Can some one assist with telling me the proper gap clearance for the intake and exhaust valves on a '96? Thank you in advance.
    Ephrata, WA
    1,125
    Valve Clearance (Cold):
    Intake: 0.05-0.09 mm (0.002-0.004 in.)
    Exhaust: 0.11-0.15 mm (0.004-0.006 in.)
    1990 TW200
    Aug 2010
    4
    Awesome thank you very much rainman
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Pulled the side covers off my '07 last night... there was a sticker inside the left one that had engine specs.
    Valve clearances, spark plug number & gap, etc.
    Still have to get the manual out for the bolt torques.
    Stephen S.
    '07 TW200:
  1. Valve clearance spec
    By yz250f4ever in forum Technical Help
    Last Post: 12-17-2012, 08:16 PM
  2. Valve clearance
    Last Post: 07-23-2012, 12:17 PM
  3. Check Valve Clearance
    By ericj in forum Technical Help
    Last Post: 04-04-2011, 02:31 AM
  4. Valve clearance question - HELP!!!
    By kj7687 in forum Technical Help
    Last Post: 03-30-2011, 02:17 PM
  5. Valve clearance question - HELP!!!
    Last Post: 02-27-2011, 02:42 AM
1990 tw200 vavle clearance
1990 yamaha 200tw valve clearance
1990 yamaha tw200 valve specs
1996 tw200 valve adjust
how to set valve clearance on my yamaha tw200
tw200 valve clearance
