Hard to start
Results 1 to 10 of 12
Thread: Hard to start
    Member smthng's Avatar
    Aug 2010
    Jacksonville, FL
    51
    Hey all, I have an '03 TW that has been running pretty good since I got the valve adjustment right. Unfortunately, the last few times I've tried to start it, it has not been at all cooperative.
    It takes about 30 seconds or more on the starter for it to finally fire. Doesn't matter what temperature or how much choke I'm using. It doesn't smell like it's flooding and if I pull the fuel line, it flows very well, so I don't think it's fuel starved either (although I could be wrong).
    The air filter only has a few hundred miles on it, but I checked it anyway and it looks pretty much like new.
    What else should I be checking here before I start pulling the carb apart?
    Oh, once it's started it runs great. Unfortunately, if I turn it off for more than a couple minutes, I have the same issue with starting it again.
    TIA!
    Senior Member wrench-puller's Avatar
    Ladysmith, B.C.
    548
    Before you go crazy on your carb, check out the post by srs 713 in regards to his battery problem. One of they symptoms was slow/hard starting, this is due to the starter pulling down all the voltage and starving the ignition system. Weak spark, no fire, no run. If you have a small volt meter, just measure across the battery terminals while cranking, you may find your problem lies there.
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    Tdub was hard to start until I opened the pilot screw a bit.
    Senior Member Kev250R's Avatar
    Orange, So.Cal.
    284
    Check to make sure you don't have too much oil on your air filter. I've seen over-oiled air filters cause similar problems.
    --Kevin
    '04 TW - Ricochet skid plate, IMS pegs, Odyssey battery, Seat Concepts seat, wide front tire. Geared low N' Slow Hidden Content
    Honda Grom
    KTM 990 Adventure
    Also, hold the bike vertical for starting. Tdub never has started while on the side stand.
    Senior Member arrowsmith's Avatar
    Missouri
    676
    My 03 will not start in gear. Maybe to much drag from the clutch so doesn't crank fast enough. Starts in neutral.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by Arrowsmith View Post
    Might be tome to check your clutch adjustment.
    Stephen S.
    '07 TW200:
    Member Brad Lamar's Avatar
    Mount Juliet, TN.
    66
    +1 on the battery. That's exactly how mine was acting for a couple of months before the battery died. New battery and it pop's right to life.
    The bike did not appear to be turning over slowly or anything else before the battery died. I thought I was having a carb or other issue.
    Brad
    Brad Lamar
    2006 TW
    Moose Barkbusters
    Skidplate
    Tusk Risers
    IMS Pegs
    Stearns Seatcover
    Junior Member Grizwilson's Avatar
    Sep 2010
    SW Missouri Ozarks
    8
    I am having a similar issue, seems to crank fine but does not start, fortunately I have added the kick start, one quick kick and it starts right up, guess I need a battery. Any suggestions?
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,405
    Quote Originally Posted by Grizwilson View Post
    ... guess I need a battery. Any suggestions?
    https://tw200forum.com/index.php?/topic/245-battery/
    jb
  1. MrBracket is doing it the hard way
    By old white truck in forum Performance and Customization
    Last Post: 12-21-2012, 04:59 PM
  2. Hard starting
    By cjnett1 in forum Technical Help
    Last Post: 09-07-2012, 07:51 PM
  3. Hard Starting
    By thal13 in forum Technical Help
    Last Post: 05-20-2011, 09:11 PM
  4. hard to start - poor spark
    By gerrychartrand in forum Technical Help
    Last Post: 05-19-2011, 10:09 AM
  5. kick start won't start
    Last Post: 01-15-2011, 06:23 AM
hard start tw200
hard starting tw200
tw 200 hard starting
tw200 either starts and runs great or not at all
tw200 hard starting
tw200 hard to start when hot
tw200 yamaha hard start
yamaha tw 200 hard to start
yamaha tw200 had to start
yamaha tw200 hard starting
