Glowing Red
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Glowing Red
    Senior Member TWBARR's Avatar
    Jul 2011
    IN
    186
    Might be a dumb question, but…..Is it typical for the exhuast pipe coming out of the cylinder to be bright glowing red. Is the motor overheating or is it just because it was dark outside? I never really noticed till last night.
    Desert, SoCal
    7,369
    You're running lean, and yes, your motor will go byebye if you keep riding it.
    Jul 2011
    IN
    186
    You're running lean, and yes, your motor's about to go if you keep riding it.
    Suggestions everything is stock. I live in Indiana at altitude of 771+/- feet with variable temps from -15* to 100*. What jetting is recommended?
    Thanks
    Desert, SoCal
    7,369
    I truly doubt it's jetting. Even at sea level with stock jetting you shouldn't be glowing red. It wouldn't hurt to rejet, but I think your problem is more basic and you'll be wasting your time unless you cure it
    Most likely it's crud buildup reducing or partially cvlogging your jets, and your carb needs a thourough cleaning.
    Next up would be the manifold boot leaking.
    Jul 2011
    IN
    186
    Thanks for the info I will clean the carb hopefully this weekend useing the carb cleaning thread. You "older" more experienced guys are awesome...
    Jul 2011
    IN
    186
    So haven't got around to working on the carb tuning/cleaning yet becuase of working on my truck. Would it make the bike run lean if the air cleaner filter is behind the guide instead of pressed against the screen. Too much air into the carb???
    918
    Quote Originally Posted by TWBARR View Post
    Not quite sure what you're asking about the guide, but put it back to the way it came stock.
    Now would be the perfect time to take your carb apart and let it soak in a carb cleaning solution while you work on your truck. Any gunk would break down while you are working on your truck.
    Sold bike.
    Jul 2011
    IN
    186
    Quote Originally Posted by pmtg View Post
    in the diagram manual for the INTAKE 11 is between 12 and 13. PO had it that way.
    918
    Put it back to stock...13,12,11. (http://www.stadiumyamaha.com/pages/O...TW200H_-_1996))
    But if you're wondering if that simple fix will solve your red pipe issue, I highly doubt it. Just dig into it when you have time.
    Sold bike.
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I assume that the TW has a simple single wall pipe
    After some power being used then most 4 strokes would have glowing exhaust pipes
    * Of course there is a wide variation in "glowing"
    Things that don't glow, bikes etc have double walled pipes so glow is inside
  1. Lumilor, electrified glowing paint
    By TdubOhio in forum Off-Topic
    Last Post: 03-24-2013, 05:44 PM
