Can't rev engine.
Results 1 to 10 of 15
    Junior Member pedroenespana's Avatar
    Nov 2011
    4
    Hi all,
    Got a problem with my TW200. Been in the garage for a few months, unused & when I came to start it, will start ok using the choke & can rev it using the choke but when I try to open the throttle it just dies. I have checked the plugs and cleaned the carb out (with the help of the usefull guide in this forum), but its still the same.
    Could it have anything to do with the petrol going "stale"?
    Any tips or comments greatfully apreciated.
    Peter
    Senior Member TuggerHiller's Avatar
    May 2011
    Long Island, NY
    362
    check the breather........possible mouse nest?
    2007 T'dub
    Cyclerack/Dual Northern Tool Boxes/AVG Miglia Helmet/Infamous Tubes/Fanny Pack/ATV Tank bag
    Senior Member rm_hm's Avatar
    1,619
    Could you tell us what year the bike is...
    Someone else had a similar problem over at ADV
    http://www.advrider.com/forums/showt...=565203&page=2
    Nov 2011
    4
    Quote Originally Posted by Rich View Post
    Yeah I saw that thread when I did an earlier search.
    The Bike is from 2005 I believe. It has low milage & has always been garaged so is clean and in good condition. There was no gunk in the Carb when I opened it up. Any thoughts on the petrol being stale?
    If your petrol is contaminated with ethanol it's probably gone bad. Drain the tank and carb and refuel.
    If that doesn't do the trick, you probably still have a blockage in your carb or a buggered float level.
    Nov 2011
    4
    Ok, thanks for the replies. I'm going to change the fuel & will report back what happens.
    Peter
    Senior Member jwtwrider's Avatar
    Aug 2011
    Central NY
    168
    Quote Originally Posted by pedro View Post
    Peter
    dont forget to drain the float bowl
    --If at first you don't succeed try, try again. If you still don't succeed BEAT IT WITH A HAMMER!--
    Member nuckingfutts's Avatar
    Sep 2011
    Hesperia Ca.
    62
    I had a similar issue. My bike would start right up and purr like a kitten, but when I tried to make it accelerate, it would fall flat on it's face. After some trial and error, with a lot of help from lzrdbrth, I found the carb slide had a small tear in it. The first time I examined diaphragm, I didn't see it. It took stretching out the rubber to find the tear. Replaced, and now all is good. Just my experience.
    Nov 2011
    4
    Ok,so I changed the fuel & it seemed a little better but a long way from perfect. Took it into see a mechanic who cleaned the carb (I suppose properly as I had already cleaned it twice) and now it runs fine. Looking back, maybe I should of cleaned it a third time after changing the fuel but was getting a bit fed up at that point. The mechanic advised me to drain the carb before leaving it in tha garage for a long period of time. Here (in Spain)I suppose the petrol isn't the cleanest.
    Thanks for replies.
    Peter
    918
    Thanks for replies.
    Peter
    I doubt cleaning it a 3rd time did anything, unless you missed spots the first time around. You may have not had the diaphragm seated properly. The little o-ring in the diaphragm may not have been seated or it was missing. I forget if you can mismatch the main jet and the pilot jet on the TW, but possibly you did that.
    Either way, glad you're good to go now. Don't lose confidence attempting other work on the bike!! That sometimes can be a big hurdle to get over when something like this happens!!
    Sold bike.
  1. BW 200 Engine
    By RTG in forum Technical Help
    Last Post: 07-16-2016, 11:08 AM
  2. How much will you pay for a TW 225 engine?
    By RisingSun in forum General Discussion
    Last Post: 07-02-2013, 12:17 PM
  3. engine oil....
    By zoomer in forum Technical Help
    Last Post: 06-14-2013, 02:18 PM
  4. Value of the engine?
    By Frank Colver in forum General Discussion
    Last Post: 02-24-2013, 02:02 PM
  5. engine oil q's
    By Henrici in forum Technical Help
    Last Post: 04-23-2011, 01:44 PM
1990 yamaha tw200 wont rev up
96 yamaha tw200 wont rev up
cant rev up engine
tw 200 wont accelerate
tw wont rev up
tw200 carb dies when accelerate
tw200 does not rev up
tw200 vibrate low rev
tw200 wont rev
yamaha tw 200 wont rev out
yamaha tw wont accelerate
yamaha tw200 mwont rev up
