1997 Base Gasket (part#?)
Results 1 to 3 of 3
    Senior Member jontow's Avatar
    Oct 2010
    Potsdam, NY
    701
    boats.net claims the gasket under the cylinder jug to be "OBSOLETE", and therefor don't allow you to add it (or the superseded part number, which isn't listed there) to your cart.
    What should I be using in place of it? Up to year 2000 uses the same "OBSOLETE" part number: 4BD-11351-00-00
    2001 and newer years use a different part, and I don't want to find myself buying one of the infamous newer gaskets and causing a problem later. I don't remember what years have that issue.
    Anyone know what to throw in the cart?
    1997 TW, well loved, a bit modified.
    Oct 2010
    Potsdam, NY
    701
    Bueller? Bueller?
    Sorry, i can't help you. I use motorcycle-specific oil and change it regularly, so base gasket replacement isn't part of my regular maintence schedule.
    My source calls for a 5VC-11351-01-00 as the part number that supercedes the number you gave.
  1. wrong base gasket?
    By BoatHands in forum Technical Help
    Last Post: 04-08-2013, 10:17 PM
  2. Base Gasket Leak
    By bogey72 in forum General Discussion
    Last Post: 08-26-2012, 10:54 PM
  3. Did my base gasket today
    By Guitarman in forum Technical Help
    Last Post: 06-18-2012, 12:47 PM
  4. 07 base gasket leak
    By small's in forum Technical Help
    Last Post: 03-25-2012, 09:41 AM
  5. New base gasket reviews
    By kennethshaw in forum General Discussion
    Last Post: 05-11-2011, 06:10 AM
