Having trouble connecting battery
Results 1 to 3 of 3
    Junior Member bundy's Avatar
    Oct 2011
    10
    Need a bit of help hooking up the battery after i stripped everything off to powdercoat the frame. Am i being a bit thick, but i can't seem to work out what hooks up to whahtt? does the negative lead from the battery earth to the bike frame? does the magneto wire attach to the starter switch? Should have probably labeled everything a bit better and taken some photos. If anyone has any pics that would help.
    Cheers
    Al
    The (-)negative battery cable bolts to the frame.
    Where the "magneto wire" goes depends on year and color of the wire. It should plug in somewhere. There are electrical schematics in the free download manuals, but you need to be sure you use the right schematic for your version of TW.
    Oct 2011
    10
    Cheers querty, managed to sort it out and get it started
  1. Gas Cap Trouble
    By canadainshiver in forum Technical Help
    Last Post: 01-21-2013, 10:45 PM
  2. trouble bleeding brakes
    By dubstep in forum Technical Help
    Last Post: 06-06-2012, 05:57 AM
  3. Having trouble starting
    By papa wheelie in forum Technical Help
    Last Post: 03-26-2012, 01:34 PM
  4. Electrical Trouble 1987
    By Hotrodjohn in forum Technical Help
    Last Post: 07-25-2011, 05:47 AM
  5. trouble getting into first..
    Last Post: 11-16-2010, 09:47 AM
