Information on crankshaft
Results 1 to 4 of 4
    Member chasejamy's Avatar
    Sep 2010
    Calif.
    59
    I will try my best to explain. How do I make sure the crank shaft is in the proper postion, before I put the timing gear
    & chain on. Do I need to pull the side cover, to do the cranksaft? Is there a mark we go by. Thanks Mike
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    Have you read the servicde manual? It does show the process. If you don't have the manual, you can download it free from this site. To answer your question, no, you shouldn't have to pull the cover if I recall correctly. However, at this moment I can't seem ot open my manual so I have to go fix that issue before I can give you a positive answer.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Hello...
    Sep 2010
    Calif.
    59
    Thanks for the information. I am going to try & put it back together on Friday. Mike
  1. Crankshaft doesnt turn counter clockwise
    By fredzaha in forum Technical Help
    Last Post: 06-17-2013, 08:17 AM
  2. information please
    By tazewellteedubb in forum General Discussion
    Last Post: 09-20-2012, 10:26 PM
  3. Carb Tuning Information
    By Larry in forum Performance and Customization
    Last Post: 09-03-2011, 05:05 PM
