Modify Case for access to front sprocket?
Results 1 to 7 of 7
    Senior Member darnold87's Avatar
    Salem, OR
    908
    I was just curious if it would be possible to modify (cut / grind) the housing to allow easy access to the front sprocket. Most bikes have easy access and it makes it so much easier to inspect, clean, and change out the front sprocket. Just curious if anyone has considered this or tried it?
    Here's a pic showing where I was thinking the case could be cut / modified:
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    918
    Quote Originally Posted by darnold87 View Post
    There is a bearing supported in the area you dotted. The bearing is lubricated with engine oil pumped through the drive shaft and out to the bearing, and the oil returns to the stator area via a port in the area you dotted. Cut out that area, lose oil, engine gets mad.
    Sold bike.
    Salem, OR
    908
    I guess that answers it!
    I'll be openning this up soon to inspect the clutch and thought'd I'd consider the mod. I guess I won't need to think about that option any longer. Thanks for the clarification... I appreciate it.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    The clutch is on the other side of the case. No need removing the left case cover to do anything with the clutch.
    Salem, OR
    908
    Wow, this shows how little I know about these bikes!
    Thanks for the info... I'll be reading up on the shop manual and hopefully gain enough confidence to open things up and check it out.
    Anyone have pics of their clutch-job? It'd be great to see someone else's experience with this...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member rm_hm's Avatar
    1,619
    Senior Member sinophilia's Avatar
    Aug 2010
    Verona, Italy
    522
    You can find a tutorial with many pictures on the TW clutch here on the French forum (you might need to be logged in, not sure).
    I'll be replacing clutch discs and springs on one of my TW very soon, it should be quite easy with the right tools.
    Red Max - 1996 TW200 - 14/45, 320mm toothed brake disc, X-Racing titanium exhaust, Ricochet skid plate, Mule hitch pins, large pegs, VeeRubber VRM274&275 tires
  1. Front Sprocket
    Last Post: 09-30-2012, 07:46 PM
  2. Front Sprocket
    By old betsy in forum Technical Help
    Last Post: 09-01-2012, 04:07 AM
  3. Front sprocket
    Last Post: 07-20-2012, 06:54 AM
  4. front sprocket
    By JMFLH in forum Technical Help
    Last Post: 10-24-2011, 01:24 PM
  5. Front sprocket noise?
    By Little Valy in forum Technical Help
    Last Post: 10-14-2010, 10:05 PM
change front sprocket
easier access to counter sprocket tw200
modified access
modify left side cover
yamaha tw200 engine diagram
