Float Bowl Gasket Sealer?
Results 1 to 10 of 20
    Senior Member rmoore2112's Avatar
    Sep 2011
    Charlotte,NC
    130
    Is it nomal to use gasket sealer on the float bowl gasket? I opened up my carb for the first time (I have had the bike about 1 month) to do some cleaning, and found gasket goop.
    I didn't notice any of the gaskets looking like this in the carb cleaning threads.
    866
    Quote Originally Posted by rdm2112 View Post
    Nope, not normal. If it's leaking, get a new gasket.
    Desert, SoCal
    7,369
    No. it isn't normal, nor is it a real good idea, as the goop frags will eventually find their way into a fuel passage. It more likely was`a quick field repair or someone's attempt to avoid buying a new gasket since they were selling the bike..
    Aug 2011
    Cayce, SC
    3,109
    I have learned that it is much cheaper in the long run to make your own gaskets.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Clean up the mess and install a new gasket, no goop.
    Making a new gasket is really not an practical option since the stock gasket is more like a cross between a gasket and an o-ring than anything else.
    Aug 2011
    Cayce, SC
    3,109
    You're right about that particular gasket. I made all new ones for my bw the other day. There are certain gaskets that will have to be purchased, but not all of them. It just depends...
    I have better things to do with my time than sit around making $5 gaskets. You'll figure it out once you have a grandchild.
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    bikebandit.com $5.95 i think.
    Aug 2011
    Cayce, SC
    3,109
    You may be right. I dont have any kids and riding and working on my bikes is my hobby. My perspective may change when I get married and have kids... but we'll see
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    You get a warm feeling when you make something with your own two hands and it works the way you intended. You can also pass that knowledge down to your kids. You don't want to lose that. Mind you I don't know how you would make one of those finicky little carb bowl gaskets.
  1. float bowl drain screw
    By boylstonrider in forum Technical Help
    Last Post: 12-20-2013, 02:46 PM
  2. float bowl chamber
    By phazer in forum General Discussion
    Last Post: 10-13-2011, 05:40 PM
  3. Float Bowl Screw
    By mike m in forum Technical Help
    Last Post: 09-04-2011, 07:03 AM
  4. Carb float bowl screws
    By jbfla in forum Technical Help
    Last Post: 10-05-2010, 02:57 PM
  5. Part number for Carb float bowl drain screw?
    By RadV in forum Technical Help
    Last Post: 09-16-2010, 06:16 PM
2005 yamaha ttr230 float bowl gasket sealer
carburetor gasket sealer
float bowl gasket
float bowl gasket sealant
float bowl sealer
how to make a float bowl gasket
make your own float bowl gasket
sealant for float bowl gaskets
sealant for the float bowls
what to use for carburetor bowl gasket sealant
yamaha vector float bowl gaskets
