Engine work
Results 1 to 6 of 6
Thread: Engine work
    Junior Member mmtdrk's Avatar
    Oct 2011
    1
    HI TW lovers
    I recently pick up a 87 (13K mi) TW. Plenty of new parts on it- rear tire, rear sporket (52) and chain.
    PO said it locked up while his son was kick starting it. Oil level looks OK to me.
    I pulled the filter out and there are plenty of shavings.
    Not sure how much engine work I'd like to do myself but may give it a try.
    Never done a tear done before so am not sure where to start.
    Any suggestions?
    Thanks!
    mm
    Download the repair manual. Read and follow instructions.
    Member Hoogie514's Avatar
    Nov 2011
    Alberta, Canada
    64
    Definitely do as QWERTY suggested and download the free manual and familiarize yourself with the bike before you begin!
    Hoogie514
    1987 TW200 - Currently undergoing a complete winter rebuild!
    2006 Suzuki King Quad 700 - Twin Air, HMF Slip on
    2010 Suzuki King Quad 500
    6,976
    Is it the correct filter with the holes on the other end? If not then you know where to start -- the head.
    Junior Member balexander's Avatar
    May 2012
    Decatur IL
    4
    did you ever tear down to see what it was? I also have same prob, finding black plastic in oil
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    Did it start? Or did the kick-starter lock up? Take a quick look at the right cover- where the kick-starter comes out off.
    It might be cracked, like the one I have in my shop, from the hole out. Next, put it in a higher gear, and rock it gently,
    clutch out, and see if the motor turns or perhaps the "locked up" comes loose. The other weak link is the kicker return spring.
    But I am not getting that it would hang up on anything if it breaks. Maybe. Anyone else have this happen?
    I think it is likely the kick-starter failed, and pieces got into its gears, but lets do the rock-it test first. And if it does
    turn the motor, drain the oil and look for metal. There is stuff in the forum about pulling covers; but you need the shop manual
    detailed advice anyway. GB
  1. Work Benches
    By Point37 in forum Off-Topic
    Last Post: 04-01-2013, 06:38 PM
  2. Painful Day at Work
    By cptrout in forum Off-Topic
    Last Post: 12-04-2012, 05:26 PM
  3. My ride to work
    By losttourist in forum General Discussion
    Last Post: 10-17-2012, 09:37 PM
  4. First ride to work......
    By kenfyoozed in forum General Discussion
    Last Post: 09-28-2012, 12:51 PM
  5. Carb work
    By 805gregg in forum Performance and Customization
    Last Post: 02-18-2011, 07:18 AM
