Flywheel starter clutch question
Results 1 to 10 of 11
    Member ldw72120's Avatar
    Oct 2011
    Central Arkansas
    69
    I recently bought a 1987 TW that had not been running for years. I got it running but it had a noise coming from the left crankcase. At times at idle it would make a noise and the engine would stop. I pulled the flywheel to inspect the starter clutch. As soon as I pulled the flywheel, all the round dowels and springs came loose. The socket head screws are not centered with the cover. It appears I've found the problem but I don't know the fix.
    Can the starter clutch be serviced? How is it disassembled? What caused the problem?
    Ephrata, WA
    1,125
    Do you have any pictures?
    1990 TW200
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    I think it speaks of these parts ...
    Oct 2011
    Central Arkansas
    69
    Quote Originally Posted by christddel View Post
    That is correct. The cover was almost covering the 3 socket head screws. I'm concerned about what caused this as I was unable to turn the cover back to the correct position. I did disassemble the clutch as pictured. I assembled it back around the starter gear and it doesn't turn smoothly. Cheap cycle parts has the complete starter cluch assembly for $80. Still curious what caused the problem.
    Oct 2010
    Belgium
    376
    Disassembling these parts may fall... Sometimes...
    We must disassembly the rotor slowly... With the bolt M16 (1.5 mm)
    To reassembly the rotor, should have a small movement of rotation (contrary to clock)
    Oct 2011
    Central Arkansas
    69
    Devon, England.
    614
    Quote Originally Posted by ldw72120 View Post
    What Christddel is saying is as you reassemble the rotor, turn the rotor slightly anti-clockwise (counter-clockwise?) as you put it on to keep the rollers in their proper place.
    Trying to write technical stuff in a foreign language is not the easiest thing, but I think Christddel does pretty good.
    Oct 2010
    Belgium
    376
    Quote Originally Posted by uktw125 View Post
    It's just that ... Thanks for the translation ...
    My method to diassembly the rotor..
    Ephrata, WA
    1,125
    Well, this happened to me. My starter motor would spin, but it wouldn't start the bike. For a couple months now, I've been hearing a rattling sound on the left side of the bike. I knew it didn't sound good, but the bike ran great so I didn't think anything of it.
    I pulled the rotor off this morning and found that the three bolts that hold the starter clutch onto the rotor were sheered off. The sheered bolts must have been the rattling noise I heard. Maybe they sheered one at a time?
    Luckily, I have a parts bike that has a rotor and good starter clutch assembly.
    How in the heck does this happen? I am lucky that I have a kickstarter!
    Bad/broken on left, good one on right:
    Notice the mis-aligned cover on the starter clutch.
    Whats left of the bolts. Now they are stuck the rotor.
    The heads of the bolts.
    1990 TW200
    Poway CA.
    2,100
    christddel, have you used a lightened flywheel in your TW? I wanted to test this in my bike.
    Thanks for all your imput.
    Ronnydog
  1. HELP! starter question
    By socalsupermoto in forum Technical Help
    Last Post: 09-25-2012, 08:07 AM
  2. A different clutch question
    By gfletcb in forum Technical Help
    Last Post: 06-15-2012, 09:18 AM
  3. Question for clutch experts
    By rastaman in forum Technical Help
    Last Post: 01-05-2012, 03:20 PM
  4. another clutch question?
    By blowout in forum Technical Help
    Last Post: 08-03-2011, 10:40 AM
  5. Clutch question
    By dennism in forum Technical Help
    Last Post: 06-17-2011, 08:55 AM
tw200 starter clutch
