13 tooth sprocket
Results 1 to 10 of 19
    Aug 2011
    Cayce, SC
    3,109
    Ive been doing a lot of trail riding and would like to be able to pick the front up for little jumps without clutch play. Does anyone that is currently running a 13 tooth front or 55 rear have any opinion about this issue?
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Desert, SoCal
    7,369
    55/14=3.92:1, 7,747 [email protected] MPH.
    50/13=3.84:1, 7,554 [email protected] 55MPH.
    Almost the same difference. 'Cept the 13 will be harder on chains.
    Stock ratio is 3.57:1, 7,042 [email protected] MPH
    Poway CA.
    2,100
    What is a 15/55?
    Ronnydog
    Senior Member gfletcb's Avatar
    Jun 2011
    181
    Quote Originally Posted by ronnydog View Post
    What is a 15/55?
    Ronnydog
    3.66:1 ? my snail is on 2 with stock sprockets, not sure if thats the same for everyone, or how much that changes with the larger sprockets but it was a concern when the larger sprocket thought crossed my mind
    Aug 2011
    Cayce, SC
    3,109
    Yeah, i've been playing with the sprocket/speed calculator ( http://www.it-ideas.net/bike/calc.htm ) and figured they were pretty close but I really just want to know if it will make the throttle a bit more "torquey"? My friend was talkin about it and thinks it will be easier to go back and forth between a 13 and 15 tooth front sprocket since I wont need to add and remove links from the chain as oppose to doing a 47 or 45-55 dual rear dprocket set-up. But at the same time, he has a split case that makes it much easier to get to the front sprocket.
    Senior Member TW2007's Avatar
    Central Washington
    464
    I would avoid the 13 tooth front. I bought one and installed it. I found that the chain on the bottom side had clearance issues with the swingarm frame (with a 50 tooth rear).
    Aug 2011
    Cayce, SC
    3,109
    Quote Originally Posted by TW2007 View Post
    Why would it have clearance issues with the swingarm frame? Not that i dont believe you, i just dont understand.
    Who here has the dual sprocket setup? Do you just keep some extra chain around for switching to the larger sprocket?
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    I have the dual rear sprocket setup with a 50 and 55 tooth. The bike certainly crawls easier with no clutch use with the 55 and will even lift the front end easier. I only cruise at 80kph on the highway and only for short distances. If I have to go longer distances I switch over to the 50 tooth. With a 5 tooth spread on sprockets I was able add links that allows the chain to work on both sprockets. It only takes 5 minutes to change over and I regularly need the extra torque in the mountains. When I added the 55 tooth sprocket I placed it on the outboard position on the axle hub. My reasoning was any chain offset would be present at lower speeds and mostly offroad. At highway speeds the 50 tooth is in the factory position and will cause no potential problems. With the wider O-ring chain you have to be very precise about spacer thickness between the sprockets or something is going to rub. Good luck with whatever you decide.
    Desert, SoCal
    7,369
    The 13 has a smaller diameter, which brings the chain run up from the bottom, and down at the top, if that makes any sense.
    It also forces the chain to make a tighter bend, which can be a factor in chain life.
    With the proper math you can come up with a pretty good spread on a dual sprocket setup and retain the same chain length, as long as you go dual in the front (think Gizmow)with two different tooth counts (13/14, 14/15 etc.) but you'd have to machine one of the shoulders off the larger sprocket for chain clearance. Radical departures will mean adding a chunk of chain when you change gearing.
    I think Qwerty did some sample math on this once upon a time.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Hello,
    To place a 13 tooth front is a bad idea...
    It is better to put of 14/60 = 4,28:1
    J' tested many possibilities...
  1. Replies: 0
  2. 60 tooth sprocket HELP
    By cthunter in forum Technical Help
    Last Post: 06-27-2011, 03:44 AM
  3. 47 tooth sprocket
    By mga60tw in forum General Discussion
    Last Post: 10-07-2010, 11:31 PM
  4. 47 Tooth Sprocket
    By FnMag in forum Performance and Customization
    Last Post: 08-26-2010, 12:26 PM
  5. 13 tooth sprocket
    By Honda710 in forum General Discussion
    Last Post: 08-19-2010, 08:17 AM
13 tooth sprocket for 2013 yamaha tw200d1
a 13 front sprocket on yamaha tw200
is 13 tooth sprocket bad for chain
tw 200 13 tooth front sprocket
tw200 13 tooth sprocket
tw200 extra tooth sprocket
yamaha tw200 13 tooth
yamaha tw200 13 tooth front sprocket
