Brake fluid leak on 05 & 10
Results 1 to 10 of 17
    Senior Member MrDNA's Avatar
    Mar 2011
    Aliso Viejo, CA
    502
    Hi all,
    Spent part of my afternoon cleaning, detailing, and doing some maintenance on both the TW's today and we noticed that our 2010 master cylinder was starting to leak in the exact same place as the leak on the older 05, who's damage is more pronounced because it's been there longer.
    So here's the leak on the 2010 just starting to happen...
    And here's what it looks like on the 2005...
    So if I do nothing to the 2010 to stop this, it will look like this 2005 picture in relatively short order, since I have actually put about 1000 more miles on the 2010 then what is on the 2005 at this point. (The new one is under warranty, so I've been beating the poop out of it... er... I mean testing)
    So, is this happening to a lot of our TW's, or did I just get the two that need to have these seals replaced?
    Someone know the how to make it stop for good?
    Thanks in advance!
    Rory
    Something witty...
    2005 & 2010 TW200
    Aug 2011
    Cayce, SC
    3,109
    Same issue on my 2010. It looks like the metal in your picture has corroded a little bit? It just looks like the paint is peeling off of mine.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Mar 2011
    Aliso Viejo, CA
    502
    Top one is the 2010, and the paint is peeling. If left alone, it will look like the second picture, which is the 05. Hoping to stop it now.
    I don't see any actual brake fluid leaking on either bike, it's more like it's seeping out.
    Something witty...
    2005 & 2010 TW200
    Frosty Hollow
    13,052
    My '05 does not have this paint peeling/chipping problem due to seepage or leak issue. Is there any kind of anti-corrisive coating that can be applied to prevent this, assuming the seepage problem is solved?
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    My 08 is the same...i cant seem to bleed my brakes properly either. they still feel sloopy
    Aug 2011
    Cayce, SC
    3,109
    I wonder if this would be under warranty? I think i'm gonna call tomorrow and find out.
    Mar 2011
    Aliso Viejo, CA
    502
    I'm def going to show these pictures to the dealer when I bring the 2010 in to have them look it over. I'm assuming this is covered by the warranty since brakes are sort of a"safety" item.
    Something witty...
    2005 & 2010 TW200
    Mar 2011
    Aliso Viejo, CA
    502
    Aluminum Jelly, perhaps?
    Something witty...
    2005 & 2010 TW200
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    Is there a chance that they are over filled?
    Try bleeding at the connections too. I always find a little air in the banjo bolts
    Aug 2011
    Cayce, SC
    3,109
    I talked to the dealer today and they seem to think it is overfilled or has a bad gasket. He wants to just sand and repaint but I think that may just be masking the problem until it comes back. Guess i'll just have to wait and see
  1. Headlight fluid level ?
    By Joboo in forum Technical Help
    Last Post: 06-24-2013, 05:21 PM
  2. Brake fluid and lithium grease
    By Dwight in forum Technical Help
    Last Post: 01-21-2013, 08:50 PM
  3. Brake fluid reservoir
    Last Post: 10-10-2012, 09:10 PM
  4. oil leak from where
    By jerz006 in forum Technical Help
    Last Post: 07-07-2012, 06:00 PM
  5. Oil leak...
    By xdac in forum Technical Help
    Last Post: 10-27-2011, 12:32 PM
