Dead Electrics on Key Turn
Results 1 to 6 of 6
    Senior Member ezman671's Avatar
    Jul 2011
    Spacecoast, FL
    178
    Turn the key to on. Sometimes lights come on and starter works and sometimes no lights and starter will not respond to start button.
    Give it a kick on the kick starter and it starts right up and lights come on.
    Try to trouble shoot but most times as soon as I touch anything lights come on and everything works fine.
    I suspect:
    1. Key switch contacts - 2 pair in the key switch 1 shorts CDI to ground (so that must be working as bike starts with a kick). Other contact supplies +12 to most of the bike from the battery. I suspect that set of contacts but as I said as soon as I touch it to measure voltages everything works fine.
    2. Starter cutoff relay - No knowledge of this but it is in the circuit that I think is not working correctly. What does it look like so I can check it out?
    Thoughts ....Ideas?????
    Senior Member TuggerHiller's Avatar
    May 2011
    Long Island, NY
    362
    Check Battery connections
    2007 T'dub
    Cyclerack/Dual Northern Tool Boxes/AVG Miglia Helmet/Infamous Tubes/Fanny Pack/ATV Tank bag
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    As wabbabee said, Clean and check battery connections first. Then start checking other connections. On most ignition switches you can wiggle key and move key back and forth slowly to see worn ignition switch. look for flickering lights while doing this.
    Senior Member yamamont's Avatar
    Sep 2011
    North of Seattle
    172
    Hey doods, my 2001 has been doing that. I pulled of the side cover and as soon as I grabbed the wiring loom with the 2 fuses, I heard a click (like in a relay) and it all came back on . As I wiggled it around it clicked and went off (no power) then clicked and went back on (power), I continued wiggling on it and it stayed on. Checked it as I went out for fire wood and didnt work with out being moved or anything?? SO I plan to get in there and find what is looose.....I think. Anyone else experience this on an electric start model? All my battery connections are good.
    Member tba02's Avatar
    Jan 2011
    San Francisco
    76
    There may be some clues in the thread below.
    https://tw200forum.com/index.php?/top...mixed-messages
    Jul 2011
    Spacecoast, FL
    178
    OK - I could go out and spend lotza $$$ on new switch and relay or I could listen to Wannabee onTug Hill.
    He is the man! Nailed it first reply. I was over thinking this. Ground wire on Battery was loose.
    I should have known I have been in that area a lot recently as I installed an XT350 tank. Bet I hit the ground connection a few times fitting the seat.
    All is well.
    Thanks to ---> Wannabee onTug Hill
  1. stator is dead:(
    By belterskelter in forum Technical Help
    Last Post: 06-02-2013, 11:24 PM
  2. Back from the dead
    By MrDNA in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-02-2012, 02:14 AM
  3. Simplify the electrics
    By leborico in forum Technical Help
    Last Post: 12-25-2011, 11:00 AM
  4. Dead things seen from my TW
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-28-2011, 03:27 PM
  5. 1987 model - upgrade electrics - possible?
    By DrT in forum Technical Help
    Last Post: 09-03-2011, 03:35 AM
