Simplify the electrics
Results 1 to 6 of 6
    Junior Member leborico's Avatar
    Jan 2011
    Montreal
    6
    Hello everyone,
    I'd like tu run my TW with simplified wiring, basically, I want to get rid of the security switches (clutch, peg...).
    Is there a simple way to do it ?
    can I just get rid of the cut off relays ? (ignition and starting)
    Also, I want simplified controls on the handlebars (turn signals only), get rid of the starter, horn and the headlight will have its own switch mounted on.
    I need advices before starting this
    (Not advices about why I shouldn't do this but advices about HOW to do it
    Thanks !!
    Eric
    Member BuddyMc's Avatar
    Huntsville, AL
    99
    Did the same thing on my daughter's TTR. Essentially you'll simply find there is a "safety circuit loop" that runs to the pertinent switch (A to B back to A) (clutch lever, kickstand, etc) so you can remove the circuit loop represented by B in the example. You should find that when connect A directly to C things will work in the Old School way. I suggest working through removing one safety loop at a time to avoid getting confused.
    Huntsville, Alabama - Have TW, Will Ride! All White 09 TW, D2Moto Pegs, Bridgestone 302 front tire, 2" higher bars, 3/4" fork preload spacer, 5wt Honda fork oil, 135mm fork oil level, exhaust tip mod, 2.5 turns out fuel mixture, 0.060 in needle shims, 130 main jet, 14/47 sprockets, 20w-50 Valvoline MC full synthetic oil, ImmixRacing rear rack, Bilt Bag on Rack, 1" front fender spacers, Battery Tender connections on new battery (installed 12/11), Coleman ATV seat cushion, 2 Agri Supply tool tubes, 30oz MSR Fuel Bottle, auxiliary 6 LED tail light, Sylvania Silverstar Ultra H4 headlight bulb, 2357 turn signals, and Superbright's 1157 LED Motorcycle Tail Light Bulb with 19 red & 6 white LEDs. Shortened rear turn signals. Bypassed kickstand switch.
    Plus a "new to me" 1995 Yamaha Virago XV 750G for Pavement Purposes!!
    918
    https://tw200forum.com/index.php?/top...post__p__30918 (scroll up within the link to view the complete diagram)
    Sold bike.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Check out the sticky threads at the top of this forum. You can download the service manuals then sit down with a pot of coffee and a printout of the wiring diagrams. You'll be able to figure out the colors of the wires you need to look for.
    Stephen S.
    '07 TW200:
    Senior Member the-wild-man's Avatar
    Sep 2010
    Columbia County, PA
    194
    I apologize for hijacking this thread, but my bike will start up and go, with the kick stand down. I almost wiped out at least once or twice, when I forgot to put it up before I took off. The safety cutoff feature has obviously been bypassed. What would I need to do to revert it back to it's original safety-rated operation?
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by twm View Post
    First, check to see if the switch is just disconnected, or completely removed. Hopefully you don't need to buy a new one.
    Second, find the wires. They may be still running down the frame & simply jumped. If they have been cut & removed higher, you'll need to find them by color code from the wiring diagram.
    Third, start a new thread & we'll take it from there.
    Stephen S.
    '07 TW200:
  1. Dead Electrics on Key Turn
    By ezman671 in forum Technical Help
    Last Post: 12-06-2011, 10:09 AM
  2. 1987 model - upgrade electrics - possible?
    By DrT in forum Technical Help
    Last Post: 09-03-2011, 03:35 AM
