Large rear sprocket needed
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Junior Member Zukman's Avatar
    Aug 2010
    14
    I am looking for a 63-70 tooth rear sprocket for my off road wheel.
    Is there anyone who knows where I can find one?
    Largest I can find is 58
    1993 TW200 in Meridian, Idaho
    1,533
    Really? Will that even work? Isn't a stock sprocket a 50T ? Are you looking to be able to climb trees with the bike?
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    I think Ronnydog is your guy. He seems to be a real serious hunter and his TW is as well, a hunting tool. I think he went large on the rear and there is a vendor that can provide what you need. Gerry
    Take care my Friend.........
    Aug 2010
    14
    Quote Originally Posted by mrgizmow View Post
    Thanks for the info
    Member Babaganoush's Avatar
    Aug 2010
    South Central Pennsylvania
    78
    All I can say is Yipes. Your top speed might end up being 35mph with that big a sprocket. I have a 54 I first bought to use in the soft woods and open fields. That was more than enough. Still had trouble climbing the steep track behind my house without a running start because the back wheel would start spinning near the top and I would come to a stop on the side of the hill anyway. I was used to my 4x4 climbing it with ease and I mistakenly thought the bike would do the same. It would be OK it the bike was All Wheel Drive. I now use a 52 as a good all-round sprocket. You can run 60 to 65 on the highway and still be able to run the woods if you want.
    Dave
    Senior Member TW2007's Avatar
    Central Washington
    464
    Quote Originally Posted by Zukman View Post
    Sidewinder fabricates sprockets and can make one for you out of various stock (aluminum/steel/titanium). Search for them on the internet.
    Mike
    Aug 2010
    14
    Quote Originally Posted by TW2007 View Post
    Mike
    Thanks much.
    Senior Member Boret's Avatar
    Aug 2010
    Northern VA
    404
    Quote Originally Posted by Babaganoush View Post
    Dave
    Hi Dave,
    Do you use the original 14 in the front?
    Did you change to an ORing chain?
    Thanks
    Aug 2010
    78
    Quote Originally Posted by Boret View Post
    Hi Dave,
    Thanks
    I am still using the 14 up front. I have settled on the 14/52 combination as the best all around for my kind of riding ( twisty country roads and even 1 or 2 miles on the Interstate) and I can still handle the dirt if I want to.
    I did change to an O-Ring chain eventually. Very glad I did- the ride is so much better. A very worthwhile upgrade. I had my dealer order me an EK chain in a longer size for the 52 sprocket and I knocked off a couple of links to fit. It was so long ago I don't remember much about the details but I did post on the old forum. www.ekchain.com/or_select.htm And thanks to QWERTY for his rec- I won't ever go back to a non-Oring chain.
    Dave
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    I've been thinking of switching my 54 for a 52, due to the massive wheel spin at the top of hill climbs...I changed everything (front, rear and chain) about 3,000 miles ago and have only adjusted the chain twice.
    You think I can still make the switch without excessive wear occuring just from switching the rear sprocket??
    I really don't want to change everything again.
    Adam
  1. JT rear sprocket question
    By silverhead in forum Technical Help
    Last Post: 04-27-2013, 04:29 AM
  2. Replies: 0
  3. 60T Rear Sprocket??
    By NHebayer in forum Technical Help
    Last Post: 06-11-2012, 11:35 AM
  4. Large Gas cap/ tank/white front fender needed
    By rastaman in forum TW200 Classifieds
    Last Post: 01-02-2012, 10:31 PM
  5. rear sprocket
    By phazer in forum Technical Help
    Last Post: 08-23-2011, 03:23 PM
52 sprocket tw200 stock chain
how does it run my yamaha tw200 with a 52 rear sproket
large rear sprocket noticeable
larger rear sprocket sizes tw200
sprocket specialists tw200 65 tooth
tw rear sproket
tw200 hill climb
tw200 larger rear sprocket
tw200 rear sprocket hill climbing
tw200 rear wheel cap
tw200 sprocket 70 teeth
yamaha tw200 rear sprocket
