Starter barely catching
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree39Likes
Thread: Starter barely catching
    Junior Member Paco's Avatar
    Mar 2017
    8
    Hey everybody, new to this and just need some help. I have a 2001 TW that i just replaced the base gasket on (the typical problem). After putting motor back in and reassembling everything I had trouble with the timing chain falling off of the bottom sprocket. I got that back on and a friend of mine tried starting the bike and to my surprise it fired right up. He didnt know I hadn't tightened the starter bolts and the second time he tried to start it, the starter spun free. So, I tightened them and tried starting it. I proceeded to spin freely without turning the motor over. I have read threads about the wires being backwards but that cant be it because the bike started twice as is. I also read the starter clutch bolts could be sheared? I'm turned away from this possibility because when the bikes in 5th gear i can roll it backwards and i can hear the starter whining. And then if i hit the electric start it will roll over the piston once and proceed to freewheel. This makes me think the starter "clutch" is still working. I also thought maybe i could bump start the bike and maybe this would magically fix my problem however the clutch is slipping enough to where i cannot start the bike by rolling. This is puzzling me as well. Anyway the bike is still together and i just wanted to see if anybody could lead me in the right direction before i start ripping parts and throwing money at it. All help appreciated! Thanks, Paco
    Ken likes this.
    Spokane, Washington
    17,427
    Welcome to the forum!!
    Quote Originally Posted by Paco View Post
    Ken likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Member wmgeorge's Avatar
    Feb 2017
    Ankeny, IA
    60
    But all was fine, before the repairs?
    Ken likes this.
    Retired guy Central Iowa, Lots of Hobby's
    Mar 2017
    8
    Yes! I rode this to school and all over god's creation. The only reason I tore it down was to replace the leaking base gasket.
    Ken likes this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,934
    As far as the slipping clutch goes, I have added a couple of ounces of Lucas heavy duty oil stabilizer. Since this seems to swell them a bit I would adjust it afterwards. I still have my original clutches. As far as the starter goes, you may just unseat it and remount and see if that helps.
    Pleasanton, CA
    5,747
    Did you happen to change your oil during this process?
    Ken likes this.
    Mar 2017
    8
    Quote Originally Posted by Ken;527073,
    I did this after i realized there was a problem and it didnt seem to fix it. I thought maybe the splines werent reaching far enough but that doesnt seem possible if the starter tightens down it has to be touching that gear.
    Ken likes this.
    Nov 2011
    norcal nutjob
    3,329
    thinking non-wet clutch type?
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    Did you have parts 1 and 2 out? 4,5,6?
    Mar 2011
    3,880
    Quote Originally Posted by AGman View Post
    I'm guessing that your timing chain has come off. You think the starter is freewheeling because you can't hear the normal sounds from the engine when it turns over because you are only spinning the crank. take the top timing gear cover off and see if the cam gear is spinning when you crank it.
    Very possible. Good idea! Hopefully a valve was not wide open when the piston came up.
  1. catching rabbits with snakes
    By phelonius in forum Off-Topic
    Last Post: 10-09-2016, 05:58 AM
  2. Yamaha Power Baby! - The little XT that [barely] could: 3rd gear sand dunes/hills!
    By kj7687 in forum Trails, Off-road, and Adventure Riding
    Last Post: 06-02-2016, 07:01 PM
  3. 2002 Clutch only catching as the lever reaches fully released
    By Audio_Phill in forum Technical Help
    Last Post: 03-20-2016, 12:23 PM
  4. Replies: 24
    Last Post: 12-21-2015, 01:36 PM
  5. Brakes catching
    By chevyluver in forum Technical Help
    Last Post: 05-03-2012, 09:38 AM
