Swingarm Questions?
Results 1 to 5 of 5
Like Tree4Likes
  • 1 Post By Fred
  • 2 Post By JerseyJeeper
  • 1 Post By TopPredator
Thread: Swingarm Questions?
    Jun 2014
    Bel Air Maryland
    4,169
    Swingarm Questions?
    I'm rebuilding my Swingarm and I could use a little help.
    Edit I figured it out
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    18,587
    Rick, have you considered going with bearings rather than the OEM bushings? If you get the sealed ones and pry off half the grease seals you can use grease pressure through the zerk fittings to seat the bearings. All those stock seals are hard to hold in position during reassembly.
    TopPredator likes this.
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    I was just just looking for the kit for him.
    Lost you on thus: "you can use grease pressure through the zerk fittings to seat the bearing" ? Seat?
    Mar 2011
    3,880
    TopPredator and socalnative like this.
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by JerseyJeeper View Post
    That's a nifty setup. My bushings are good all I needed was the rubber parts and I figured it out.
    Thanks if I ever wear out my bushings I'm buying this setup.
    JerseyJeeper likes this.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
  1. Swingarm extension
    By TWGIRL in forum TW200 Classifieds
    Last Post: 08-24-2014, 08:01 PM
  2. Building a competent T-Dub - questions. Lots of questions.
    By kawazacky in forum Performance and Customization
    Last Post: 04-05-2014, 10:39 AM
  3. TW swingarm on ebay
    By Schleppy in forum TW200 Classifieds
    Last Post: 04-13-2013, 08:27 AM
  4. Swingarm Removal
    By ezman671 in forum Technical Help
    Last Post: 07-09-2011, 07:39 AM
  5. Extended Swingarm
    By TK200 in forum TW200 Classifieds
    Last Post: 02-06-2011, 12:44 AM
