Dies when I twist the throttle
Results 1 to 10 of 20
Like Tree41Likes
Thread: Dies when I twist the throttle
    Junior Member NPHLYT's Avatar
    Feb 2017
    29
    2004 with 295 miles. NOS tank. New petcock. clean (strained)gas). Rebuilt carb. Sprayed carb cleaner through every orifice and hole I could find.
    Starts and idles. When I twist the throttle is bogs down and dies.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Remove the pilot jet and thoroughly clean OR replace. Add a double dose of Seafoam to fresh gas and run for 15 minutes. Let sit overnight and run again with the fuel mixture. Repeat for a week and let us know how it works. You're welcome.
    P.S.- I had the same issue with mine, worked like a charm.
    Feb 2017
    29
    Jets new. Came with kit.
    Ken likes this.
    rbm
    rbm is offline
    Jan 2011
    4,300
    Quote Originally Posted by NPHLYT View Post
    OEM or aftermarket jet?
    littletommy likes this.
    Feb 2017
    29
    This one:
    https://www.amazon.com/dp/B00T6J4EK8/ref=cfb_at_prodpg
    Jul 2012
    Wet-ern Washington
    1,404
    It sounds to me like you may have lost your main nozzle when the carb was apart. It's the silver bushing looking thing in the carb parts pics. Without it it messes up your fuel delivery when using the main jet... giving it throttle. The bike may run at idle, because it is using the pilot circuit at that point. Give it throttle and the main circuit kicks in, and without the parts in the right places, it pukes and dies. It is a very easy part to loose when disassembling the carb, and it's happened to many of us.
    ITEM #12; PART #5LB-14341-00-00; MAIN NOZZLE (or the little silver bushing)
    - Leisure Time Larry -
    2004 TW200, 13-54 gearing, Shinko 241, Race Tech Emulators, Procycle front springs, Works Performance rear shock, Emgo handguards, Luckybike mirror risers, Ken Sean DS foldable mirrors, 30mm Tusk bar risers, Seat Concepts, Kick Starter kit, Plasti-dip camo coat, Cycle Pumps, Ricochet Skid Plate, flood and spot LED pod lights, Sena, Garmin etrex 20 GPS, IMS 313114folding shifter
    Senior Member Rider21's Avatar
    Aug 2015
    Reno, NV.
    429
    Check the air box?
    Beauty is as beauty does.
    If it works good, it's beautiful.
    Feb 2017
    29
    The main nozzle is in place, but I did not change it. I have the carb off again, I will R and R.
    Quote Originally Posted by lrppcer View Post
    Feb 2017
    29
    What do I check in air box? The air filter is new (dealer item) and I cleaned all of the dust out of it.
    Quote Originally Posted by Rider21 View Post
    Check the air box?
    6,957
    Open the idle mixture screw another turn and make sure the hole in the pilot jet is clear.
  1. Bad throttle response, won't go past 50% throttle video
    By trcooperone in forum Technical Help
    Last Post: 05-10-2016, 04:46 PM
  2. a new twist on the "teardrop"
    By jeffrolives in forum Off-Topic
    Last Post: 07-08-2015, 11:31 AM
  3. Replies: 26
    Last Post: 08-31-2014, 08:25 AM
  4. engine starts with electric start, dies with throttle.
    By mc_lamma in forum Technical Help
    Last Post: 04-21-2013, 01:49 PM
  5. A twist on the TW
    By straightpipez in forum General Discussion
    Last Post: 02-13-2012, 02:18 PM
yamaha tw200 dies when giving throttle
