Time to Service Ruth
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree47Likes
Thread: Time to Service Ruth
    Jun 2014
    Bel Air Maryland
    4,169
    I brought My 2006 "Ruth" into my little shop for her yearly service. . I've listed all the items I can think of...am I missing anything?
    Fork Service inspect and service. DONE
    Inspect front breaks and sand. DONE
    Replace break fluid. DONE
    Inspect rear breaks and sand off glaze. DONE
    Inspect wheel bearings F&R. DONE
    Lub Swingarm. DONE
    Change oil clean filter. DONE
    Replace plug. DONE
    Clean and Lub chain. DONE
    Adjust valves. DONE
    Grease Speedometer gears DONE
    Clean and treat air filter DONE
    Torque head bolts DONE
    Lub all cables. DONE
    Check Tire pressure DONE
    Check lights treat with Di-Electric grease. DONE
    Di-Electric grease on all connections DONE
    Clean and Lube helmet lock. DONE
    Paint Exhaust DONE
    Touch up Paint. DONE
    Deep water Mod. DONE
    Check Battery. DONE
    I need to replace my Base Gasket at some point in the future.
    I bought an HID headlight last August and the High/Low beams are reversed. I swapped the High/Low wires on the connector and now my high beam indicator light stays on all the time. The indicator light is dimmer on the low beam setting. I don't recommend HID headlights but of course LEDs are becoming more popular.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Dec 2015
    San Diego
    1,857
    Depending on type service battery.
    Sep 2014
    Mamaroneck, NY
    2,176
    I know you'll do it when you check the chain, but mention the sprockets, as well.
    littletommy and TopPredator like this.
    May 2013
    Groton, NY
    2,663
    After all that's done you should start thinking about a good weekend or 2 to haul your camper (with Ruth) up to Central NY.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by scotti158 View Post
    It's your turn to visit me. Like the Green Ridge ride
    scotti158 and littletommy like this.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by Smitty Blackstone View Post
    Good point...I didn't mention them because I replaced both sprocket along with an O-Ring chain last year.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    May 2013
    Groton, NY
    2,663
    Quote Originally Posted by TopPredator View Post
    Long loop is 100+ miles....I usually do that before breakfast.
    TopPredator likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Jun 2014
    Bel Air Maryland
    4,169
    I chipped away on my list tonight. I also pulled my spark plug...does this look lean?
    I hope this grill paint works well
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    May 2013
    Groton, NY
    2,663
    I'm getting "Invalid Attachment specified. If you followed a valid link, please notify the administrator" when I click on the attachments.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Apr 2014
    Dryden NY
    6,336
    Far from an expert but I would say it looks too lean.
    Tom
  1. Ol' Ruth is Running Rough
    By TopPredator in forum Technical Help
    Last Post: 08-14-2016, 08:50 AM
  2. I let Ruth play on the Interstate today
    By TopPredator in forum General Discussion
    Last Post: 06-25-2016, 08:33 AM
  3. Long time lurker, first time poster
    By TW-Brian in forum General Discussion
    Last Post: 08-30-2014, 02:59 PM
  4. Long time lurker, time to finally buy.
    By jrpitdog in forum General Discussion
    Last Post: 10-04-2013, 09:39 PM
  5. Video time... (big-time stuck!)
    By bookm in forum General Discussion
    Last Post: 05-30-2012, 09:54 PM
