Turn Signal Wiring
Results 1 to 8 of 8
Like Tree18Likes
  • 1 Post By EWB
  • 2 Post By Smitty Blackstone
  • 3 Post By Iaintlikeu
  • 4 Post By littletommy
  • 2 Post By EWB
  • 2 Post By joeband
  • 2 Post By EWB
  • 2 Post By EWB
Thread: Turn Signal Wiring
    Senior Member EWB's Avatar
    Oct 2015
    Campbell, CA
    674
    Turn Signal Wiring
    Swapping out my turn signals. The ones I have are two wire. Anyone know which wire for the front is the running lights (so I can cap it off) blue or green? Pretty sure blue are the running as the rear only has black and green.
    Sent from my SM-G935T using Tapatalk
    littletommy likes this.
    Sep 2014
    Mamaroneck, NY
    2,176
    I don't remember.
    Use a test light or even the lights themselves to test.
    littletommy and TopPredator like this.
    Senior Member Iaintlikeu's Avatar
    Apr 2016
    Elizabeth Pa 15037
    124
    extra fuses!
    Spokane, Washington
    17,260
    1st John 1:9
    John 3:16
    John 3:17
    Oct 2015
    Campbell, CA
    674
    Yeah i figure i can see if it flashes or stays lit should answer the question
    Nov 2011
    norcal nutjob
    3,305
    the rears are two wires, and the fronts are three, so as you said what's left over should be the difference. can't you just pull that bullet and see if the rest work?
    Oct 2015
    Campbell, CA
    674
    On it tomorrow. Rear is done
    Oct 2015
    Campbell, CA
    674
    Now they sit inside the rack
  1. Replies: 8
    Last Post: 03-11-2017, 06:46 PM
  2. Turn signal out
    By DanBarwick in forum Technical Help
    Last Post: 07-25-2016, 11:01 AM
  3. Turn signal device cancels the signal after the maneuver.
    By jtstdub in forum Performance and Customization
    Last Post: 02-02-2016, 07:58 AM
  4. Need some turn signal wiring help asap...
    By backroadnomad in forum Technical Help
    Last Post: 03-11-2014, 09:16 AM
  5. Turn Signal Wiring
    By Jtrez in forum Technical Help
    Last Post: 12-21-2012, 04:01 PM
