Carb Hose Location?
Results 1 to 7 of 7
Like Tree11Likes
  • 4 Post By GaryL
  • 1 Post By cowboyjeff
  • 1 Post By Tennessee TW
  • 3 Post By Purple
  • 2 Post By cowboyjeff
Thread: Carb Hose Location?
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    Carb Hose Location?
    I need a little help, I put a new Carb on a 91 Tw 200 and there is a hose on the back right side that is about 1" long that connects to a why fitting.
    I ran the one pointing down to bundle with the over fill hose, What I don't remember is where is the hose pointing up suss post to go?
    Nov 2013
    West Jordan, Utah
    207
    Never mind, I just stumbled upon a old post that said just get rid of the Y. Thanks bunch.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,997
    Quote Originally Posted by cowboyjeff View Post
    Bad info in that thread that said get rid of the Y! That Y has a purpose and it should have another line up under the fuel tank at a higher position. This prevents water from being sucked up when you do a deep water crossing and the lower tube get submerged, it is a secondary breather tube.
    1987 Yamaha BW350 Big Wheel
    Nov 2013
    West Jordan, Utah
    207
    Thanks Gary, thats just what I done with it. It really dose make good sence.
    littletommy likes this.
    Member Tennessee TW's Avatar
    Dec 2013
    Tennessee U.S.A.
    40
    What does the upper hose plug into?
    1978 Honda XL 125s
    1984 Honda XR 250 R
    1994 Honda XL250 L
    1996 Kawasaki KLR 250
    Mar 2015
    Ynys Môn
    4,550
    It doesn't plug in - just take it as high as possible on the frame and leave it open ended ..... (see post 3 from Gary)
    (I assume that;s the one you were talking about - the upper one that leads off the "Y" ) .....
    littletommy, cowboyjeff and Ken like this.
    - Hidden Content
    Nov 2013
    West Jordan, Utah
    207
    On my new Carb I melted the new Upper vent hose before I figured out where it belonged, I replaced with some 1/4" Black irrigation Tube I had hanging around.
    I just ran it up and and thru the hole in the middle of the frame rail, about the center of the tank.
    littletommy and Purple like this.
  1. Replies: 7
    Last Post: 08-28-2016, 02:30 PM
  2. Hose from carb?
    By SlayerOne in forum Technical Help
    Last Post: 05-04-2014, 06:42 PM
  3. Replies: 5
    Last Post: 12-20-2013, 11:05 AM
  4. Weird carb hose
    By 805gregg in forum Performance and Customization
    Last Post: 11-20-2010, 08:41 PM
